Results 1 to 9 of 9
Thread: Equipment Pad
    Mar 2013
    CT
    363
    Equipment Pad
    Does anyone have one of these for their pump/filter?
    Seems like a pretty good alternative to concrete. Certainly cheaper than having a concrete pad poured.
    https://www.poolsupplyunlimited.com/...ic-pad/82125p1
    16 x 32 In-Ground vinyl, 21,000 Gallons, Hayward Cartridge Filter, Hayward Tiger Shark robotic cleaner, Taylor K-2006 Test Kit
    Jun 2014
    17,333
    Re: Equipment Pad
    I have something similar (see My Pool link below). Held-up pretty good so far. Later I may need to expand my pad though, so I'm undecided as to if I will buy another and set them side-by-side, or just remove and pour concrete. But it's easy and convenient to use that's for sure.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    10,158
    Re: Equipment Pad
    Yep---------been sitting there for 8 years.
    30,950
    Re: Equipment Pad
    Mine sagged a little in the middle from the weight of the pump so it wanted to hold a little water after a rain. I drilled a couple of holes and the problem was solved
    Jul 2011
    St. Paul, MN
    244
    Re: Equipment Pad
    That looks easier than concrete, but I'm not sure it's cheaper. 2 80lb. bags of quikrete will make a 2'x2' 4" thick slab. That will cost about $8.
    20'x40' Oval 27,000 gallon Vinyl IG, Coverstar Auto Cover
    Hayward MaxFlo SP2303VSP, Sta-Rite PLD50 30 sq. ft. DE filter
    Rheem 266,000 btu natural gas heater
    Dolphin Nautilus Plus with Clever Clean
    TF-100 testkit w/ Speed Stir
    Apr 2010
    East Texas
    10,158
    Re: Equipment Pad
    Yeah..........but SOMEBODY has to pick up those two 80 lb. bags!
    Jul 2011
    St. Paul, MN
    244
    Re: Equipment Pad
    Like I said, concrete is cheaper not easier!
    Mar 2013
    CT
    363
    Re: Equipment Pad
    Quote Originally Posted by faby3003 View Post
    Unfortunately concrete isn't cheaper when you're having someone else do it. I'm getting too old to do projects like that...
    Any problems w it being black - absorbing the sun/heat and all? They do have a gray one but it's half the weight and obviously not as heavy duty.
    poolnewbies5874's Avatar
    Aug 2015
    SW Ohio
    126
    Re: Equipment Pad
    Our builder just used 4 18 inch concrete pavers and pea gravel to make our equipment pad. We expanded it out with the same when we added our heater
    12,000 gallon Blue Hawaiian 'Hamilton' fiberglass IG 15x34 freeform, Pebble Beach finish, Pentair Clean & Clear 100 filter cartridge, Pentair SuperFlo 1.5HP pump, Stenner pump, Raypak 266k heater
    8/2015 pool build photos TFT-100 test kit
