Hi all,
Quick timeline, in case it matters. Two months ago I moved into the house. A couple of weeks after moving in, got to work on the pool. Pool store water test showed too many dissolved solids and too much CYA, so drained and refilled. Looked awesome, pool guy came and put starting chemicals (not liquid chlorine), and everything looked great. Two weeks ago, came home one night to find my pump running dry; it never primed. Fought (and am still fighting) those issues for 5 days (no pump/no filter). During this time water turned green. I now can get the pump to reliably prime and come on, so about ready to tackle my green swamp...however, I am going on vacation for two weeks, leaving in one week. Leaving 5/19, back 6/1.
Current water numbers, according to pool store:
FC: 0
PH: 8.2
TA: 140
CH: 80
CYA: 0
Total Available Chlorine: 0
I do have a TF-100 test kit arriving tomorrow (though I'll have to learn how to use it).
In my very limited understanding, might my pool be a candidate for shocking with dichlor or trichlor, since my PH is high and my CYA is low (and obviously my FC is low)? Is that reasonable? Or should I still go with a liquid chlorine solution and work the PH and CYA numbers independently after getting the FC up? The Chem Geek's Chlorine/CYA chart doesn't even have a row for 0 CYA, so I would need some assistance with that.
Second major question: With one week to do this, then gone for two weeks...is it best just to do nothing and wait, throw some chlorine tabs (how many?!) in and do nothing else until I get back, do something else entirely different (what?), or should I go ahead and try to read and learn how to SLAM all in the one week before I go on vacation...and then do it all again when I come back?!
Third major question: I **think** I have my pump reliably starting on timer now. Should I leave the pump on the time schedule while I'm gone? I might be able to get the neighbors to look in on it...if so, how often and what should I have them do/check for? Or should I just turn everything off since I already have a murky green pond instead of a pool? One other caveat...I do not believe my vacuum is working, only the skimmer (pump sucks air in and loses prime if I open the valve to vacuum).
Thanks for the help...this site is awesome!
- Paul
FC: 0
PH: 8.2
TA: 140
CH: 80
CYA: 0
- Paul
