Thread: Baja shelf tanning shelf
    Apr 2017
    Pass Christian ms
    12
    We're doing a pool remodel and want to add a small area i the shallow end for our 1 year old to be able to stand and splash in the water. My question is in order to attach this to the preexisting pool does the floor of the pool have to actually be jack hammered to access rebar? The pool has no rounded edges they are all straight cuts so what I wanted to do was come off of the second stair (rounded radius stairs to the nearest wall the area of this shelf will be approximately 4' wide by 7' long water depth on shelf will be approximately 14" deep. Any info on attaching the block structure to this 1970 gunnite pool would be greatly appreciated
    Killer95Stang's Avatar
    Sunny SoCal
    696
    Re: Baja shelf tanning shelf
    In the remodels I've seen where they add a Baja shelf, they remove the plaster in that area and rough up the surface. They then drill holes to epoxy in a rebar structure and build it up to the form of the shelf. Then they spray new gunite and replaster the entire pool.
    Pool done!! (backyard = work in progress) 32' x 19' inground freeform with 7' spa, baja step w/ (2) bubblers, stonescapes mini pebble finish, rock waterfall feature, 12" raised bond beam, Intelliflo VS, Whisperflo feature pump, (3) 5G Color LED's, FNS + DE 60, 400K Master Temp, Easytouch 8 w/ remote, Intellichlor IC40, Vision Classic Ceramic Kamado smoker, Margaritaville DM1000!!! Party Coming Soon!!
    TF-100 Test Kit w/ Speedstir
    Apr 2017
    Pass Christian ms
    12
    Thank you very much for the quick reply, would you think the bottom of the pool should be approximately 8-12" thick? The way of the shed built with cinder block rebar enforced vertical and horizontal and backfill with clay? Pack backfill with vibratory plate and approximately 6-8" thick of concrete??
    Apr 2017
    Pass Christian ms
    12
    Bump
