Results 1 to 11 of 11
Thread: Ran out of CL testing solution
    LeeH's Avatar
    May 2017
    Cherokee, AL
    6
    I'm trying to finish the SLAMing process. All of the debris is out, PH is 7.4, TA is 120, CH is 150, and CYA is 40. I was doing the overnight test last night. I tested at 8 pm CST and FC was at 17 ppm with CC at .5 ppm. I was testing again this morning at 5 am CST and ran out of Taylor 0871 solution. I ordered some replacement solution yesterday from the TFP supply store, but it will more than likely not be here until Friday. I use the 10 ml line on the tube where the multiplication of number of drops is by .5. When I ran out of solution, I had put the 12th drop in and the sample was still plenty reddish. The filter has been running since Sunday and the water looks pretty decent; just really cloudy.
    My question is this: Should I just hold off on adding any more liquid chlorine (Pool Essentials 10% from Wal-Mart) until I get more solution or should I add one more gallon? Personally, I think I should NOT do anything without the ability to tell what the FC/CC levels are, but I haven't been doing this very long!
    LeeH
    26,700 gal | IG | Vinyl
    Sand | Hayward - 1 hp
    2007 | Taylor K-2006
    Polaris 360 - 1/2 hp booster | County Water | No Restrictions
    40,862
    Re: Ran out of CL testing solution
    Sticky situation and I think your personal thought is a good one ... don't usually want to add without being able to test.
    But, I don't want you to fall too behind either.
    At high FC levels, you lose a lot to the sun every day. Even at a normal FC level, you would lose 2-4ppm of FC every day.
    So, I would suggest adding about 5ppm of FC in the evenings until you have your reagent and can get back to the SLAM ... seems like you are close and might be at the final filtration stage.
    LeeH's Avatar
    May 2017
    Cherokee, AL
    6
    Thanks! I'll take the suggestion. My pool is in the open sun all day too; only shade is from sunrise till about 10 am.
    LeeH
    40,862
    No problem ... sounds like you are well on your way to great pool season
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,299
    You could always take a sample to the pool store and let them spin the wheel..
    Aug 2016
    Warminster, PA
    36
    ^^^^that's pretty funny...
    Viking Coronado IG Fiberglass 13k gallons, Pentair Intelliflo VS Pump, Pentair Cartridge Filter (320 sqft), Pentair Electric Heat Pump (125k btu), Pentair Intellichlor IC20 SWG. TF-100 Test Kit. Located in SouthEastern PA.
    LeeH's Avatar
    May 2017
    Cherokee, AL
    6
    That is funny, but I think I'll pass! I've had enough of that over the past nine years! I did go to one yesterday to see if they might possibly have some FAS-DPD reagent. When I asked them for it and mentioned the need to test my FC and CC levels, they looked at me like I had two heads and a tail!!
    LeeH
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    LOL!!! And they're the pros?
    LeeH's Avatar
    May 2017
    Cherokee, AL
    6
    Received my testing solutions and retested:
    FC 1
    CC 1.5
    PH 7.4
    TA 100
    CH 150
    CYA 40
    added more 10% liquid chlorine (512 oz) to bring the FC back up to 16. Will test again for a baseline OCLT. Water is still pretty cloudy. Perhaps it will clear up now that I can properly monitor the FC/CC levels!
    Richard320's Avatar
    Jan 2010
    20,299
    Quote Originally Posted by LeeH View Post
    FC 1
    CC 1.5
    PH 7.4
    TA 100
    CH 150
    CYA 40
    No point in even trying the OCLT if the CC is above .5 and the water isn't clear.
    LeeH's Avatar
    May 2017
    Cherokee, AL
    6
    Oh yeah, I forgot about that part! Thanks man!
    LeeH
