Thread: Ideal CYA when using Liquid Chlorine
    May 2017
    Oxford MS
    16
    I live in Mississippi and it gets pretty darn hot in the summer. What is the ideal CYA when using liquid chlorine for all sanitation? Also, if I add more stabilzer how long should I wait before I SLAM the pool?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,312
    Re: Ideal CYA when using Liquid Chlorine
    30 CYA is ideal for doing the SLAM. If you're below that, add enough to get to 30 and just pretend it's all dissolved already and SLAM at 12 FC.
    After the pool is all sparkling and crystal clear, raise it to about 50 CYA. Unless the pool is out in a wide-open field where it gets full sun all day, that should be plenty.
    40,895
    There is no ideal. It is a balance of pros and cons.
    Raise up to about 30ppm of CYA for the SLAM.
    If your pool gets a lot of sun, then after the SLAM raising the CYA up to around 50ppm might lower your FC losses to the sun.
    May 2017
    Oxford MS
    16
    Ok, thanks. My CYA just happens to currently be 30!
    40,895
    Well, then you are off the races ... SLAM away
