Thread: Sand filter questions
    Jun 2015
    Ottawa/Ontario
    357
    Hi all
    I read on a few websites that sand should be replaced every five to seven years...because the sand edges get worn down and won't trap solids and particulates as well. I don't think that passes the sniff teat, but wanted some thoughts from this group.
    Another question I have is about the plumbing - the sand filter does not have quick connects - should it? When i pop the top off to give it a deep clean, the plumbing will still obviously be connected - should I take this opportunity to cut the lines and install quick connects?
    Much appreciated any insight from the TFP gurus...
    Tom
    18000 IG, SWG, 1/2 HP Tri Star + Solar PV direct DC Lorentz pump, Sand filtrt
    20000 gallon, Vinyl liner IG, SWG, Sand Filter, Hayward 1/2HP + Lorentz direct solsr PV pump
    Jun 2014
    17,322
    Re: Sand filter questions
    Hi Tom! Your gut is correct on both notes. Sand doesn't go bad unless someone decides to corrupt it with pool store junk that gums it up. The deep cleans are all you need. As for the quick disconnects ... yes. Ideally you should have some unions so that you can remove the multiport more efficiently without wrestling with the plumbing, or in some cases cutting the lines. Hope that helps.
    Jun 2015
    Winnipeg, MB, Canada
    283
    Sand is millions of years old. Getting beaten by waves, glaciers, and wind. A few years in your pool filter isn't going to ruin it in any appreciable way.
    And yes to quick connects. It's not necessary but a little extra time this time will save you time every time you do it.
    23K gallon, vinyl liner, 1hp pump, 300 lb sand filter, Fafco solar panels, jandy lite 2 heater, TF-100 Test Kit
    Jun 2015
    Ottawa/Ontario
    357
    Oops - meant sniff TEST! Haha. Thanks for the responses!
    Aug 2008
    Pensacola, Fl
    63
    When I did my deep clean a few days ago, I had to cut the pcv pipes and install unions. Piece of cake. Just remember to remove about 1/2-3/4 inch on each of the pipes so the rest of your plumbing isn't distorted.
    About 23,200 gal vinyl in ground, "stop sign" shaped 22x22, Polaris 3900 cleaner, Hayward Aqua Plus Pro Logic Controller, Hayward T-15 SWG cell, Hayward S244T sand filter.
