Thread: First time issue with pool.
    Jun 2016
    St. Louis, MO
    24
    So I moved into a house with a pool last season. Used only liquid chlorine last year and not one issue. Today I woke up to a cloudy pool. Could still see the bottom, but cloudy for sure. Anyway I tested water and I was at 0 chlorine because I just ran out yesterday. I was in a bind so I used some shock I had bought before I found TFP. Anyway I added 2lb of Clorox shock plus. Active ingredient is sodium dichloro-s-triazinetrione. Let it run a couple of hours and it seemed more cloudy when I came back. Also on a couple of the ledges there was a white almost toilet paper dissolving in water looking substance. I brushed the entire pool and added another 2lbs of Clorox shock plus. Just curious if anyone knows what it is. BTW I took a sample of the water before adding the last two shock packs. Here are the TF-50 results:
    PH 7.5
    FC 7.5
    CC .5
    CH 275
    TA 120
    CYA 35
    IG 20k Gunite Chlorine
    StaRite Max EPro 1HP Filter Pump, Booster Pump for Polaris 380, 1HP Water Feature Pump
    Cartridge Filter
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    10,152
    Re: First time issue with pool.
    Almost sounds like white water mold. I'd do an OCLT.
