Thread: New pool setup with upgraded pump
    Apr 2017
    GA
    18
    I'm installing an Intex sand filter pump today on my Coleman 22ft pool. I've actually just set the pool up, and I won't be using the filter system it came with. yesterday I was putting on pieces that came with the original pump in case I missed something (First-time pool owner). My pool has the two nipple outlets that have the top hat looking plugs. They do not have cut off valves. What I am wondering is if I need the plastic screens that came with the pump that fit over the two inlet holes on the inside to filter for leaves? It would appear to be very hard if I need to clean the sand pump basic as I need to use those top hat plugs to hold the water in. I assume with my upgraded pump (that already has a leaf basket and I will have a skimmer on it too) that I don't need those two screens on the inside as well.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Re: New pool setup with upgraded pump
    Hey there,
    I've given you a bump to the AG forum where more owners of these types will see and offer some help.
    Essential Links:
    Jul 2016
    Noblesville, IN
    30
    No expert, but I think you'll want those filters even with the basket strainer.
    BTW, did you have to buy additional adapters to go from 2" down to 1.5"? My pump came with two, but I need 4 (one at each of the "B" outlets, and one on each of the two input sides of the T connector (where the two separate intakes combine into a single hose to go into the strainer basket).
    Anyway, if you did have to get two more, where did you get them and if not, what does your setup look like as I may have something wrong. . .
    Pete
    Pete and Family
    Graduated from baby wading pool to Quick Set Intex 10 ft to Intex steel frame 12 ft over the last 5+ years
    Just purchased BestWay 22 ft x 52 in on clearance - will graduate to it next spring!
