Thread: Pool Conditioner
    Apr 2017
    Las Vegas
    20
    Pool Conditioner
    I have used the Natural Chemistry liquid pool conditioner and it has helped but still need to bump up my CYA some more. I know the liquid is more $$ so is there any particular brand that is better than another? Or is it all the same?
    Also I have read about the sock method in the skimmer, would it also dissolve if I put it in a sock in one of the chlorine dispenser that floats on the top of the water? Or would the lack of water flow through it make it not dissolve?
    22,000 Gallon In-ground Gunite / Plaster (New pool, plaster done March 2017) with Spa
    Pentair Intelliflo variable speed pump and 2HP water feature pump
    Pentair Easy Touch System w/ Iphone app
    Pentair Gas Heater and Pentair Auto Vacuum
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,303
    Re: Pool Conditioner
    Quote Originally Posted by bpdunlv View Post
    Chemically it's all the same. Go for price..... probably going to be Walmart.
    If you don't want to set the sock in the skimmer, you can dangle it in front of a return and let that pummel it. If you just let it bob off a floater, it will take longer to dissolve, but it will work.
