Results 1 to 20 of 20
Thread: New pool owner
    May 2017
    Morris Alabama
    15
    New pool owner
    No problems with the pool, water clear, pool store says Chem levels look good. I have a come of questions..... I have an auto chlorinator, it takes 3 inch tablets, how many should I put in at a time, how long should I run my pump, what does regular maintenance involve?
    26K GALLON, IG, 1HP PUMP, VINYL LINER, CHLORINE.
    Oct 2015
    San Diego, Ca.
    801
    Re: New pool owner
    Be prepared to for the pros to tell you 0 tablets.
    35,000 Gal. - 40x20x8 - Plaster - SWG Pentair IC 60 - Barracuda G3 Vacuum - Hayward c1750 Cartridge Filter - Blue Torrent VS 1.5hp pump - Pool is 45 years old.
    "I'd build a deck over my pool if I didn't have a SWG"
    May 2017
    Morris Alabama
    15
    Re: New pool owner
    I'm going swg next year or two, so just looking for what I need o sustain myself through maybe 2 summers.
    Oct 2015
    San Diego, Ca.
    801
    Re: New pool owner
    I speculate that you may be advised to use only Liquid Chlorine as the sanitizer. The problem with the tabs is the stabilizer in them accumulates to the point that any amount of chlorine will be ineffective. Result ...a cloudy green pool. The upside is that if your current stabilizer level is low enough, you could make it the 2 years. Regardless, you'll need the recommended test kit to see what's what.
    May 2017
    Morris Alabama
    15
    Re: New pool owner
    Even with weekly shock treatments?
    Jul 2011
    St. Paul, MN
    244
    Re: New pool owner
    Quote Originally Posted by drmnjms View Post
    Welcome to the forum! In order to help you, we need to have water test results from a reliable test kit (either the TF-100 or Taylor K2006C). Pool store test results are not to be trusted.
    20'x40' Oval 27,000 gallon Vinyl IG, Coverstar Auto Cover
    Hayward MaxFlo SP2303VSP, Sta-Rite PLD50 30 sq. ft. DE filter
    Rheem 266,000 btu natural gas heater
    Dolphin Nautilus Plus with Clever Clean
    TF-100 testkit w/ Speed Stir
    Oct 2015
    San Diego, Ca.
    801
    Re: New pool owner
    "Even with weekly shock treatments?"
    Shocking should never be necessary when you get set up correctly.
    Jul 2011
    St. Paul, MN
    244
    Re: New pool owner
    I suggest you read https://www.troublefreepool.com/cont...ater-chemistry
    If you properly maintain the free chlorine level in your pool you will never need to "shock" your pool. There are many members of this forum who have not "shocked" or SLAMed their pool in years and always have crystal clear water. Once you learn about pool water chemistry and get one of the recommended test kits taking care of your pool will be very easy.
    How long you run your pump will depend a lot of factors, but if your 1hp pump is a single speed, it will be between 4-12 hours per day. If you search the site for "pump run time" you will find many threads discussing this.
    Once you have one of the recommended test kits, you will want to test your water every day for a couple of weeks while you learn about how to maintain your pool water's chemistry. After that, you will probably test every other day. Most forum members add liquid chlorine to their pool every day or every other day.
    For other maintenance, you will generally brush the walls of your pool and vacuum the floor of your pool once per week. Many people have automatic pool cleaners to do this for them.
    ta2dwonderwoman's Avatar
    Jul 2016
    fall river ks
    502
    Re: New pool owner
    and be prepared for the pool store to tell you that this is all poppycock and it is critical to shock weekly...they know not of what they speak...trust these folks and learn the tfp way, you will save time, money and frustration!
    Windy ☆ 22ft round, 11,400 gal, intex ag vinyl, SF70110-1 Intex sand filter/2800 gph pump, CS8110 intex swg, city water, solar heater, TF100 test kit/speed stirrer, over the wall intex skimmer~fall river ks~SLAM, Pool School, Recommended Levels, Recommended Chemicals, Pool Math
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,752
    Re: New pool owner
    Lots and lots of money...
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    Sfpat's Avatar
    Jul 2016
    tulsa
    113
    Re: New pool owner
    Especially with weekly shock treatments as the "shock" also adds stabilizer - the more you shock the faster the stabilizer level rises. I switched to the TFP method (bleach) a year ago and have not "shocked" my pool since and have crystal clear water. This after 15 years of constantly fighting algae with tabs, shock, algecides, etc and lots of money. I now spend about $10/wk in bleach with the occasional gal of muratic acid.
    40 year old pool, 35k gal w/spa, gunite replastered July 2016, Hayward Sand filter, Hayward 1.5 hp single speed pump, TF-100, Kreepy Krauly suction side cleaner Dolphin M400
    May 2017
    Morris Alabama
    15
    Re: New pool owner
    Okay. I will do that. Thanx.
    May 2017
    Morris Alabama
    15
    Re: New pool owner
    So....just to clarify, I need to purchase the test kit, turn off the auto chlorinator, test the water and go from there?
    Jul 2011
    St. Paul, MN
    244
    Re: New pool owner
    Yes, that's right. I would add half a gallon a day of bleach until you get your test kit, or leave your chlorinator on until you get your test kit in order to maintain you FC level.
    May 2017
    Morris Alabama
    15
    Re: New pool owner
    Until I get the kit, how many tablets should I put in at one time?
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,752
    Re: New pool owner
    None, until you have a test kit to accurately measure your CYA level. Most forms of solid chlorine add CYA, and without knowing your current level we don't want to add any more. Only use liquid chlorine, aka bleach, to raise your free chlorine (FC) level.
    Pentair IC40 SWG
    May 2017
    Morris Alabama
    15
    Re: New pool owner
    Any particular type of Muratic acid I need to use?
    triptyx's Avatar
    Apr 2016
    1,474
    Re: New pool owner
    31% Muriatic Acid - you can find it at most big box stores.
    Be careful if going to Home Depot - they have "Pool Acid" which is only 15%, and then "Muriatic Acid" which is 31%. Choose the 31% stuff.
    8,500gal plaster in-ground with attached spa, two floor drains, one skimmer. Chlorine, City Water.
    Pentair WhisperFlo 1hp Pump, MagnaTek Midcentury EPlus motor, Pentair CleanNClear 200SF Cartridge filter, Purex Triton MiniMax 250 Gas Heater, Pentair SunLite, AutoFill.
    Kreepy Krauly Cruiser, TF-100 with SpeedStir. :D
    May 2017
    Morris Alabama
    15
    Re: New pool owner
    How long do I aerate the pool and how soon after I add the acid?
  20. Back To Top    #20
    triptyx's Avatar
    Apr 2016
    1,474
    Re: New pool owner
    Aerating the pool is done to raise the pH as part of the procedure for lowering your TA (total alkalinity).
    For now, you're going to add acid to lower pH only to about 7.6 (no lower than 7.2). There is no need to aerate yet.
