Results 1 to 12 of 12
Thread: Liquid chlorine vs powder shock
    Jun 2016
    Hurricane,wv
    10
    Pool store told us to shock our pool with 5lbs powder shock. We typically use liquid chlorine so how much would that be? They said to only use the powder...
    Also, our pool is vinyl and calcium hardness is low. Is this a problem?
    kcb
    in ground, 11,800, vinyl, s200 sand
    40,862
    Re: Liquid chlorine vs powder shock
    Who cares that the pool store told you to use 5 pounds ... if they told you to jump off a bridge would you?
    We teach to maintain your pool based on accurate testing. Do you have a good test kit?
    You can not "shock" a pool once and hope for the best ... well, you can, but that is a lot of HOPE!
    We teach to follow the SLAM process when there is a problem in the pool and that is guaranteed to clear up the pool.
    No, a vinyl pool does not need to worry about low CH.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,299
    Quote Originally Posted by Kcbpool View Post
    Powdered "shock" can be a number of different chemicals: Dichlor, Trichlor, Cal-hypo in differing strengths, or Lithium Hypochlorite. If you already bought it, tell us what the label says and we can get you an equivalence in bleach. If you haven't already bought it, don't. The pool store told you an outright lie, either from ignorance or more likely because the profit margin is higher on the powders. You might have noticed the store was full of buckets and boxes of chlorine stuff...
    If you want to know more, check out Pool School - How to Chlorinate Your Pool Pool School - Recommended Pool Chemicals and ABCs of Pool Water Chemistry
    Also, low CH is no problem in your vinyl pool as there is no plaster to dissolve.
    Jun 2016
    Hurricane,wv
    10
    Label says calcium hypochlorite 78%
    Thanks for your help!
    40,862
    So, that is going to add calcium to your pool (which you do not need) and it could cause the water to become cloudy.
    Problem is, why 5 bags? why not 3 or 10? We are just guessing without reliable test results.
    What if you add 5 bags and a few days later the pool is still in bad shape? You would have just thrown money into the pool and then relying on the pool store to sell you more stuff.
    Jun 2016
    Hurricane,wv
    10
    Test results at the store said free chlorine .22, total chlorine 3.09 and combine chlorine 2.87.
    Richard320's Avatar
    Jan 2010
    20,299
    Each one pound bag is the same as 136 ounces of bleach -- a little more than a jug.
    Jun 2016
    Hurricane,wv
    10
    Thanks!
    40,862
    I fear you are still planning to just dump 5 bags in (or the bleach equivalent).
    Is that your intention?
    Jun 2016
    Hurricane,wv
    10
    Well.... from what I have read, the goal is to get to breakpoint chlorination which means add 10x the combined chlorine... Combined chlorine was 2.87. I have liquid chlorine 10% and the bags of shock that they sold me. So whatever is the best way to achieve the goal is what I want to do.
    40,862
    Well .... you did not read that here. Breakpoint chlorination is non-sense.
    You need to follow the SLAM process.
    You need to decide if you want to learn the TFP method that we teach or continue to try the pool store methods. Trying to mix advice is just going to cause confusion, likely not work, and waste everyone's time and your $.
    Jun 2016
    Hurricane,wv
    10
    You are so right. Thanks.
