Thread: Opening Pool
    Jan 2016
    KS
    63
    Opening Pool
    Here is the situation. my pool is closed and has L shaped PVC to keep jets above water level. I am getting a new cover and have to raise the water up to the skimmer.
    Would it be an issue to fill the pool before officially opening it? (IE starting anything/removing those l shaped pvc/etc...) They need the pool level raised before they can install the cover. I just do not want to open the cover to remove everything because once I do I cannot close the cover without the new cover.
    Thanks
    36,000 Gallon, 40x20 IG, Vinyl, Hayward S- 200 Sand Filter, 300,000 MasterTemp heater, 1hp Superpump, Polaris 9550 sport, TF100 test kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,312
    Re: Opening Pool
    I can't think of any reason. You're past the danger of freezing.
    Jan 2016
    KS
    63
    Re: Opening Pool
    thank you for reply. I can't imagine it causing any damage but wanted to make sure I was not overlooking anything
