Thread: PH regeant
    Rsmith's Avatar
    Apr 2016
    Central Md.
    113
    PH regeant
    I have a taylor 1000 that has a bottle of R0014. I stopped by the pool store to pick up a replacement bottle and they only have r0004 for the 2000 series. Will that still work? 5 drops?
    Central Md. 37 X 21 24K IG Custom Gunite with Anvil Quartz finish. Raised Spa.
    Sta-Rite Natural Gas Heater. Intellichlor IC-40 SWG, Sta-Rite 450 sq ft. Cartridge Filter.
    Pentair 1.5 Hp Variable Speed Pump. TF100. Dolphin Z-5. First swim 5/26/16
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Re: PH regeant
    No sir. Sorry.
    Essential Links:
    May 2012
    Toronto, ON
    472
    Re: PH regeant
    Can't you just use a lot more - like 15 drops of R0004 or use a much smaller water sample size. I thought that what matters here is the tint from yellow at 7 or below to bright pinky purple at 8 and above. And the tint seems to be the same no matter how much you add.
    Vinyl 18'x36' in-ground 100,000 L, Jandy Aquapure 1400 SWCG, Jandy Lite2 heater, StaRite System3 filter, Evac tube solar heating panels
    JoyfulNoise's Avatar
    May 2015
    14,091
    Re: PH regeant
    Quote Originally Posted by wayner View Post
    The R-0014 is meant to be used with a comparator block that has roughly 5.5mL of water in it. The R-0004 uses the 2000 series comparator which has a 44mL water sample for pH. So, since the volume difference is about a factor of 8 but without knowing the concentration difference between the two reagents, it's hard to know how many drops to add exactly. I did the experiment with my water which is at 7.4 -
    5 drops of R-0004 in the #9056 (2000 Series Comparator block) and 2 drops of R-0004 in the midget comparator that comes with the K-1000 -
    Based on those results, I would think that the R-0004 is about 1.5X more concentrated than the R-0014 drops....
    Matt
    Rsmith's Avatar
    Apr 2016
    Central Md.
    113
    Re: PH regeant
    Thanks for the help, I think Ill order a new bottle from TFTestkits. .
