Thread: Rubber washer on pump shaft - is seal failing?
    Feb 2017
    Longview / Texas
    96
    Yesterday I noticed what appears to be a rubber washer spinning around on the shaft of my pool pump between the motor and the impeller housing. Is this normal? I don't know why that would be there unless something is loose in a seal. There is no water dripping but I would like to go ahead and fix this if it could be a future problem. This new pump has only been in service, typically 8 hours per day on low speed, for about a month and a half. It is a Pentair 1 HP 2 speed pump. The pump is not making any noise and still has a very strong flow to the pool even when on low speed. The pump was on when the pictures below were taken. Thanks for any insight.
    24' x 52" 13.5K gal. Doughboy Autumn Breeze AG pool. Pentair CC200 Cartridge Filter. Pentair Dynamo 1HP 2 speed pump. Dolphin E-10 robot. TF-100 Test Kit. Confer CCX-AG with curve add on pool steps. My Pool Build.
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    2,192
    Re: Rubber washer on pump shaft - is seal failing?
    Nope that is a part that is supposed to be there. It's called a slinger and its job is to keep any water that leaks past your seal from traveling down the shaft and into your motor.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    Feb 2017
    Longview / Texas
    96
    Great. Thanks for that information. One less thing to worry about. I wish they included that in the parts diagram in the manual. Thanks again.
