Thread: Pool/deck bonding issue...
    TomGallopavo's Avatar
    Apr 2016
    Hillbillyville, MO
    175
    We recently put a small deck on our pool. Every so often we get a static shock if we are on the deck and touch the water. I have google searched and plastic/composite decking does not have to be bonded. We have followed the regulations and the pool is properly bonded. Should I dig down and connect the deck to the wire? BTW, the deck is floating and does not touch the pool (can be seen in the build thread in my sig). Thanks for looking!
    Spring 2016 Install, 24'x54" Saltwater LX AG Round Pool (13500 gal.), AquaPro 200 SQ. FT. Cartridge Filter System 2-HP 2-Speed Pump, Solaxx Saltron Retro Jet RJ Saltwater Chlorine Generator, Aqualuminator Above Ground Pool Light, TF-100 Test Kit w/ Borate and Salt, Well Water.
    Jun 2015
    Stockholm, Sweden
    261
    Re: Pool/deck bonding issue...
    The composite is not electrically conducting, so not possible to bond. In fact, it is probably the combination of the composite material, prone to generate static electricity, and the fact that the water is bonded (is it?), causing electric discharge when touched, that is the problem. A wooden deck or unbonded water would not have the issue. Not much you can do about it I think, other than minimizing static buildup by walking barefoot.
    Intex Ultra Frame 24'x12'x52" (732cm x 366cm) rectangular pool
    Intex SF80220RC (1600 GPH) pump/sandfilter
    Intex SF10220 (1050 GPH) pump/sandfilter driving the
    Intex Automatic Pool Cleaner
    Intex 8220 ECO SWG, Brilix XHP100 9kW heatpump
    Apr 2016
    Hillbillyville, MO
    175
    Yes water is bonded. Shocks not even close to socks coming out of the dryer so I guess we will live with it. Thanks!
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    2,192
    Do you have any electrical devices on your deck that could be the source of the problem?
    If theres no electricity touching your deck then you can try running a bare copper wire across the underside of the decking boards close to were you get in and out of the pool. Connect the wire to your bonding loop. You don't need to bond your deck per code but doing so wont hurt anything either. Do you have any electrical devices on your deck that could be the source of the problem?
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    Apr 2016
    Hillbillyville, MO
    175
    There is no electricity near the deck nor will there be. I think I will connect a wire to the deck bolts near the pool, run it up along the underside of the composite (with connections), then down to the bolts on the other side, then connect to the bonding wire running around the pool.
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    2,192
    It just might solve your problem. Even though the deck isn't conductive bonding it to your loop should give the static charge a place to go so that it doesn't build up.
    Chuck-
