Thread: New Pool - 1st numbers from TF-100
    May 2017
    Gaffney, SC
    26
    I added 4lbs of conditioner yesterday after a CYA test of 0, and will be "creeping up" to the 8lb 9oz needed according to poolmath. I also added the required amount of 8.25% bleach to get the FC to 4.0.
    Here are my numbers from this afternoon
    CYA - not tested, will test again next week
    FC - 3.5 - 4 (I accidentally dropped two drops at once, so I don't know if it would have taken 7 or 8 drops)
    CC - 0
    TC - 3.5 - 4.0
    TA - 30
    PH - 6.8
    Temp - 70 degrees
    This is where I am now - where do I go next? I'm super new to this so I need a bit of hand holding at this point, until I'm comfortable with all of this. Thanks in advance!
    Serena 33'x52" AGP, 25,600 gallons
    1.5 HP Pentair Pump, Heyward Sand Filter
    TF-100 Test Kit, Speed Stir
    PH Pen
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: New Pool - 1st numbers from TF-100
    Add baking soda to raise your TA to 60. That will also raise your pH.
    Here is what you are looking for, Pool School - Recommended Levels
    Here is how to add chems to your pool and what they do, Pool School - Recommended Pool Chemicals
    Apr 2017
    Phoenix
    500
    Your 4 FC level seems low. Even though you have to wait to test cya, just assume the amount you added is in there. Then whatever cya you are shooting, use enough bleach to get in high end of range. For example, if you added stabilizer to get pool to 30cya you should be adding enough bleach to get FC to 6 or a little above. Once it drifts down to 4 you need to add again.
    Here is the chart: Pool School - Chlorine / CYA Chart
    16,000 gallon in-ground pebble tec pool. Hayward SP3400VSP Eco-Star Pump, Pentair Triton 2 TR-100 sand filter, A&A 5-port in-floor pool cleaner, Pentair Intellibrite 5g color changing pool light, Polaris 965iQ Robotic Pool Cleaner, OG Pool Math Subscriber and most importantly a Taylor K-2006C test kit.
    Test Kits Compared
    | SLAM | Chlorine / CYA Chart |
