Thread: New skimmer not working
    May 2017
    Columbus, IN
    3
    Post New skimmer not working
    Hi! I have a 16' round Intex above ground pool with a 1200 gph sand filter attached. I bought the skimmer for it and put it on the pool today and it does nothing . Leaves and debris just wash around it. If I disconnect the hose and put my hand over the intake I feel really good suction. I can also see the water moving across the surface coming through the output but there is absolutely no suction or draw to the skimmer at all. I have backwashed my filter. I have ensured there is no air in any of the hoses. I'm lost. The required gph for the skimmer is 800 gph. Any ideas on what I need to do?
    Thank you!
    Renea
    40,877
    Re: New skimmer not working
    Welcome to TFP!!!
    Can you post a picture of what skimmer you added?
    If it does not have a weir door on it, then it is not going to pull much across the surface.
    May 2017
    Columbus, IN
    3
    Thanks Jason. It does not have a door on it.<
    Attempting to attach a photo of my skimmer.
    Renea Summers
    above ground 16' x 4' Intex round pool.
    single outflow to pump
    sand filter/pump 1050 gph
    40,877
    Hmm, well I have no experience with those, did not realize it was not a through the wall skimmer. How someone else can jump in.
    domct203's Avatar
    Jun 2015
    CT
    3,898
    Best thing I ever did was ditch that Intex skimmer and install a thru the wall skimmer (see my signature for link to skimmer install).
    Next best thing I did was get a larger filter.
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    May 2017
    Columbus, IN
    3
    Quote Originally Posted by domct203 View Post
    Thanks Dom👍🏻 That is my next step. I'll check out the link. One more question, what would you recommend for a filter upgrade? Mine is sand and circulates 1050gph.
    Renea Summers
