Thread: New LED light using existing fiber optic cables
    May 2017
    Lincoln, ca
    2
    I want to replace my halogen fiber optic pool lights with LED lights. The problem is the Builder buried the two Fiber Optic Cables directly into the ground so I have to connect the LED light to the current fiber optic cables. They are both 225 strands that run to both lights. But the new LED light will only receive 200 strands. If I only use a hundred strands from each fiber optics cable will the pool be bright enough with the new LED light?
    Hacky387
    May 2016
    Northeast MA
    139
    Re: New LED light using existing fiber optic cables
    I may be completely missing something here, but how are you going to run an LED light off of a fiber optic cable? The LED light needs low voltage power, and isn't the fiber optic cable just a bunch of glass fibers? Where will your power come from?
    Inground vinyl 23'x40' Aspen shape, ~27K gallons, Sta-Rite Intellipro 2 VST Pump, Sta-Rite System:3 Mod DE Filter (60 sq ft), Hybrid In-Floor System (Paramount Valve with Caretaker Heads), AquaComfort Heat Pump, 3x Savi Melody Sol 28W LED Lights, Pentair IC60 SWCG, EasyTouch Automation with ScreenLogic, TF-100 test kit.
    May 2017
    Lincoln, ca
    2
    Quote Originally Posted by jtrovato21 View Post
    The LED driver light will be in a junction box where the old halogen light was and the light will shine into the fibers and then out to the pool. I have the pool guy here now and we are going to try it. I will let you know if it works
    Hacky387
    May 2016
    Northeast MA
    139
    Quote Originally Posted by Hacky387 View Post
    That makes more sense now. I was thinking the LED light was going at the pool end, like a nicheless LED light. Did your idea work with having the LED shine into the fibers?
