Page 1 of 3 123 LastLast
Results 1 to 20 of 50
Thread: Wish I found this forum before building....Not too late? Pics!
    May 2017
    Avon, CT
    98
    Hello everyone. New pool owner in Connecticut. Pool is still mid-construction but I wish I had found this forum before agreeing to all the various options and equipment, etc. Normally I do my research. Not sure what happened this time. So the pool is a 16 x 34 "Mountain Lake" shape. Need to find out the volume. Along with the included equipment is a Frog Leap twin pool frog system which from what I've read here is a mistake. Its already installed but it wouldn't take much for me to eliminate it or just not use it going forward. Also included was a 1 HP pump. Seems a bit on the small side. Let me know your opinions. Don't worry about me being offended or insulted. I can take it.
    BTW, What does "BBB" stand for? I already know I need to do it...
    Have a lot more to read here, just thought i'd say hi.
    Jan 2012
    'burbs of Augusta, Georgia
    8,550
    Re: Wish I found this forum before building....Not too late? Pics!
    Hey JBB! Welcome to TFP!
    BBB was an old acronym for "Bleach, Borax, Baking Soda"....three items we use in pools instead of their expensive pool store versions. We stopped using that term when folks mistakenly thought they needed to go out and buy all that...when in actuality they may not. Bleach is the one thing every pool uses at one time or another though!
    Your build looks good..... fun days ahead!
    Can I be a debbie-downer on one item though? That mineral/chlorinator device. We *never* suggest folks put metals in their water (silver, copper, etc) which is what that mineral pack does. And pucks will also add too much stabilizer if you're not aware of it and watch out for the problems it brings when the CYA stabilizer gets too high.
    I would invite you to dabble your toes in the Pool School articles, starting with ABCs of Pool Water Chemistry.
    Have you ordered your test kit yet? We recommend only two on the market: The TF-100 or Taylor K-2006C. Both use Taylor reagents but the TF-100 is set up so that you have more of the reagents that you'll use most often. You can buy either at: tftestkits.net or Pool Supply World.com or Amazon. I'd go for the first, as they ship out of NC and will get to you fastest.
    Bring back any new pics you get as well as questions!! We loveeeee pics!
    Maddie
    Skippy's Pool Cooler --> Skippy's New Fountain Our Build --> Our Pool Solved Our Sloping Yard
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,296
    Welcome!
    I did a little googling. It looks like your pool is somewhere between 17000 and 19000 gallons. My pool is 16000 gallons and my 1 hp works just fine. I manage with only a couple hours a day.
    Order the test kit now so you'll be ready. And ditch the frog as soon as the builder completes his startup and leaves.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,606
    Wow what a gorgeous build! Is it 8 feet deep in the end?
    Echoing yippy / richard, I'd have that frog system removed from the plumbing if possible.
    Dolphin E10 Cleaning Robot.
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    656
    What they said. You are going to love that AquaCal Heatpump. We had their biggest heater/chiller on our last pool. Went with Pentair this time, as it is all easy integration with EasyTouch. Enjoy the experience. It is a thrill a minute at this stage.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,892
    Beautiful pool, kill the Frog....
    Support the site
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,125
    If I were to make a recommendation, it would be make sure your pump is at minimum, a 2 speed pump. The low speed will save you a lot of electrical usage and still filter the water just fine and produce a lot less noise than a single speed pump.
    Of course if you wanted to go all out, the variable speed pumps are awesome. And if your electric costs are 20 cents KWH or more, the VS pump would definitely pay for itself in saved energy costs.
    Divin Dave,
    May 2017
    Avon, CT
    98
    Wow, such helpful members. Thank you all.
    Quote Originally Posted by YippeeSkippy View Post
    Hi Maddie(My Daughter's name ) Thanks for all of your help. Yeah I don't plan on using the frog system after reading many of the posts here about it. Seems very expensive and not at all what I am after. In fact I am somewhat disappointed that my builder suggested it for me. As far as the test kit goes I need to find out what the builder provides me but if its not the TF-100, I will be ordering that one right away.
    I did a little googling. It looks like your pool is somewhere between 17000 and 19000 gallons. My pool is 16000 gallons and my 1 hp works just fine. I manage with only a couple hours a day. Order the test kit now so you'll be ready. And ditch the frog as soon as the builder completes his startup and leaves.
    Thanks Richard! I was calculating around 19K myself. Glad to hear the pump should be fine. Wish I could find the model information on the Hayward website though. Its a Model SP1607z1m and there is no sign of it on the website anywhere so I'm guessing its an older outdated model. I wanted to confirm its a single speed motor. I'm guessing it is.
    Quote Originally Posted by borjis View Post
    Thanks. Yes, 8 feet.
    Quote Originally Posted by Divin Dave View Post
    Thanks Dave. Unfortunately as I said above I think its only single speed. You would think it would say it somewhere on the pump
    May 2017
    Avon, CT
    98
    Today I will be explaining to my pool installer that I no longer want to go with the frog system. We'll see how this goes over. I'm sure he will try to talk me out of it.
    16' x 34' Irregular IG vinyl, ~18K gal, Hayward S210T Sand Filter, Hayward 1HP Single Speed pump, AquaCal SQ125 Heat Pump, TF-100 Test
    Jul 2009
    Long Island, NY
    267
    Quote Originally Posted by jbb2388 View Post
    It's your money to spend the way you see fit. I'd ditch the frog and go for a SWG instead. You will be much happier in the long run.
    Free-form concrete walls with vinyl liner, 18,000 gallon capacity, Jandy 1.5HP e-Pump, Jandy DEV48 DE filter (using cellulose media), Jandy AE2500 heat pump, Jandy Aqualink Power Center with 14-blade cell kit and Jandy PDA-P8 wireless control system.
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,802
    Quote Originally Posted by poolneophyte View Post
    If you go with a swg, make sure your ladder, diving board, etc are salt water rated. My pool was installed with a pool frog hybrid swg system and they didn't use a salt water rated ladder or diving board. I've already replaced the ladder, and need to do the diving board stand soon.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    May 2017
    Avon, CT
    98
    Thanks for the replies guys. I won't be going with SWG anytime soon. Gonna stick with BBB method going forward. Those mineral and chlorine cartridges for the frog system are insane!
    Jan 2012
    8,550
    When y'all are ready for the SWG (I'd guess by next year when you tire of lugging jugs of bleach home) the space that Frog system sits now will easily accept the SWG. It won't be difficult to slap that puppy in there at all. You and your husband may be able to do it yourselves if y'all are the slightest bit handy.
    Maddie
    May 2017
    Avon, CT
    98
    Lol, I AM the husband and yes I am very handy. I can't imagine that bags of salt are any less desirable to lug around, lol.
    Spoke to my installer over the weekend. He said no problem about taking out the frog system and would take care of it. He sounded confused though and asked me what my plan was to treat the water and asked if I was planning on using chlorine floaters. I said no, liquid chilorine and that I have been doing quite a bit of reading the last few weeks. I ordered my TF-100 test kit. It should be here this week. I am very anxious to get started. Our bldg inspector has been dragging his feet getting over to give us the go ahead to start backfilling the pool so all work has been at a stand still and it just sits there completely full as I wonder how long before it turns green with algae. Supposedly the inspector is coming this afternoon and they will be finishing the backfilling and plumbing and getting the pump and filter running tomorrow. I sure hope so. I am dying to get started.
    Jun 2016
    Walhalla, SC
    275
    It's better than you think! You'll need maybe 10-12 bags (40#) to get started, and then maybe 1-2 each season. It's easy to run the math to see if it's cheaper for you than lugging bleach around, but it's definitely less effort! It's easy to convert at any time, so you can always wait until the bleach thing gets too annoying.
    20x40 28kgal in-ground vinyl built 2011, liner replaced 2017
    Pentair Tagelus TA60D sand filter, Pentair SuperFlow 1HP pump, Intellichlor IC40 SWG, Dolphin Active 30i
    City water, TF-100 test kit + speedstir.
    Recommended Levels | Chlorine/CYA Chart | SLAM
    Jan 2012
    8,550
    You can go ahead and put some chlorine and cya in the water while waiting for the inspection...can't you?
    Maddie
    May 2017
    Avon, CT
    98
    I don't know. Can I? I still haven't gotten any equipment or anything from installer so I was concerned about putting liquid chlorine in before having the returns running to mix it or at least before having a brush to mix it manually. Is there anything I can do at this point? Thanks guys for the replies.
    May 2017
    Avon, CT
    98
    Can I add chlorine at this point without the pump and filter system running yet and without any tools to mix the water up yet?
    Jun 2016
    Poplar Bluff, Missouri
    344
    I'll let the others chime in on if you should add the cya and chlorine without having any equipment to mix it up but I do want to say that is a beautiful pool, even more so once you get all the landscaping done and the water is TFP crystal clear!!
    AGP: 21' x 52" : 10,000 gallon
    100 lb. Sand Filter / 1 hp pump
    11-5 full sun
  20. Back To Top    #20
    Jul 2013
    Long Island, NY
    247
    If you're not sure about a SWG, I recommend a Stenner pump w/15 gal container for the chlorine injection...one of the best things I ever did! I fill the tank every few weeks. I have a dual electronic timer, one for the pool pump and one for the injection pump. Chlorine gets added 3 times a day for about 15 min each time. A few folks from this forum have installed them, so you can do a search and see some pics.
    20x40 33k gal in-ground Bella Blue Pebble Fina pool w/diving board, 1 HP Hayward pump, Raypak RP2100 335k BTU NG mV heater, Pentair Quad DE 60 filter, Pentair 261173 multi-port valve, Stenner 45MPHP10 pump w/15 gal tank, Intermatic ET1125CR dual electronic timer, 1.5" lines, two skimmers w/socks, Poolskim, vacuum line, ColorQ Pro 7 kit, TF-100 kit, speedstir, 2 froglogs, Dolphin Discovery Robot. Wine is the answer, what was the question?
