Results 1 to 10 of 10
Thread: Replumbing question
    el duderino's Avatar
    Jun 2008
    Austin, TX
    118
    Replumbing question
    I have had a lot of issues priming my single speed 1.5hp Pentair Whisperflo pump over the years and have had the inlets and outlets replumbed several times. The last plumber hard plumbed the pipes not leaving much (any) room to splice in again that I can see.
    I'm considering putting a union back on the outlet side to stop the leaking that is currently happening, but not sure how/where to splice in.
    Any suggestions are very welcomed!
    Our pool- (Completed March 2009)
    20k gallons, 38x15 Free Form Gunite (3.5'-8'), 26' Negative Edge and 7' Negative Edge spa with blower, Midnight Blue Diamondbrite, AquaLogic PS-8 control, Goldline Salt Chlorine Generator, 2x1.5hp Pentair 2 speed pumps, Pentair DE Filter, Pentair 400k BTU Heater, and BlackMaxPolaris 280 w/ Hayward booster pump, Pentair Prowler 920, DIY Stenner Chlorinator
    Jun 2008
    Austin, TX
    118
    Re: Replumbing question
    Ps, there is not a union there now. It is self bonding tape which I applied to attempt to slow/stop the leak. It did not work btw
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,312
    I can't tell from the picture whether the 3 way valve is connected with an internal or an external coupling. Those valves are dual-sized, so if it's internal, just saw it off at the valve and replace that whole L-shaped section. Put a larger coupling, then a reducer, and go. Or stay larger until after the elbow, then reduce at the pump.
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,317
    el,
    I think it should be a crime to install pumps without pump unions...
    I'd install this basic type which has an O-Ring on the threaded side....
    I'd cut the pipe up near the valve where you have the most 2" pipe exposed..
    Jun 2008
    Austin, TX
    118
    It's plumbed external on that part of the 3-way
    Jun 2008
    Austin, TX
    118
    Quote Originally Posted by Jimrahbe View Post
    el,
    Jim,
    I agree! I have some of those very unions on the way just not sure how I'm gonna make it work. I'm not sure there's enough 2" exposed to connect union.
    Jun 2008
    Austin, TX
    118
    Would it be possible to cut out the reducer and go from there? I've never done that but heard it's possible.
    Richard320's Avatar
    Jan 2010
    20,312
    Quote Originally Posted by el duderino View Post
    If the plumber wasn't thorough about the primer and all, it might separate... Check out Removing PVC pipe from connectors/collars via burning glue or torch
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,609
    el,
    Jim I WHOLEHEARTEDLY AGREE!
    I've noticed, the last 2 big services I've had done (replaced multiport and heater) both
    service techs installed unions. (thank god!)
    I see a new pool build with no unions on the pumps or heater and think what the heck!?!
    I would insist on unions for a new build for sure.
    Dolphin E10 Cleaning Robot.
    Jun 2008
    Austin, TX
    118
    I also wonder if I cut as close to the valve as possible, if the internal connection would be open. I may need to go take some measurements.
