Results 1 to 8 of 8
Thread: New guy on the block..
    Clint1980's Avatar
    May 2017
    Orange Park, FL
    12
    Hello!
    new to the forum and the pool ownership world. So far...MISERABLE! After spending my life savings at the pool store it seems, I came across this forum, read some articles and this approach makes much more sense to me. I just finished pool school, albeit pretty quickly, so I'll read through again. My TF-100 is on the way, but I tested with my cheapo over the counter test kit and this is what I have as of now: total chlorine is zero. (Kind of surprised by this it's been perfect till now). PH:8.2 TA:450 CH:650 CYA:6.5. I have been battling this pool since we moved in a month ago. From clear to cloudy to greenish to yellowish green. Pool store said chemicals were perfect. Kept doing what I was doing, keeps getting worse. I'm hoping I'm having a pollen issue and not a mustard algae problem. I have a Polaris P825 that cleans up nicely, but small particulate just gets blown back out of the filter and clouds up the pool. Then it resettles. I feel like I'm close with this thing, but I can't seem to get it under control so that I can enjoy myself. Any help is appreciated, and I look forward to learning from you all!
    35,000 gal Inground marcite pool. Hayward high rate sand filter with 300lbs sand. 20 gpm filter, 65 gpm backwash. 1.5 hp pump(model UST 1152), TF100 test kit
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,315
    Re: New guy on the block..
    We really like pictures around here. Is it possible that you can post a few of your pool?
    Bob - INTEX 12x24 owner (not setup yet), 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    ta2dwonderwoman's Avatar
    Jul 2016
    fall river ks
    502
    is a CYA of 6.5 even a thing? I would suggest looking at some videos that explain how to test correctly and then retesting that and making sure you know what your CYA is for sure. that is really the jumpoff point for most everything that tfp teachs...you are in good hands with these folks, they will lead you to the promised land...well, to a sparkly pool anyways!
    Windy ☆ 22ft round, 11,400 gal, intex ag vinyl, SF70110-1 Intex sand filter/2800 gph pump, CS8110 intex swg, city water, solar heater, TF100 test kit/speed stirrer, over the wall intex skimmer~fall river ks~SLAM, Pool School, Recommended Levels, Recommended Chemicals, Pool Math
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,296
    There shouldn't be anything large enough to see with the eye blowing out the returns. Your filter ain't filtering like it should be.
    There's a good chance your filter is channeled. Basically your fine sand has formed clods with huge cracks between then that allows stuff to flow through and out. Busting up the clods (and checking the sand level inside) is a messy job, but will probably pay dividends. See Deep Cleaning a Sand Filter
    Once you get a real test kit in your mitts, it should be easy to tame the chemistry.
    Clint1980's Avatar
    May 2017
    Orange Park, FL
    12
    My apologies, fat fingered my phone keyboard. CYA is 65
    Jul 2016
    fall river ks
    502
    Lol, that makes more sense
    Clint1980's Avatar
    May 2017
    Orange Park, FL
    12
    thanks I'll give that a try next!
    Clint1980's Avatar
    May 2017
    Orange Park, FL
    12
    Gonna try to attach these pics...ignore the yard, it's all a work in progress! Lol
