Results 1 to 11 of 11
Thread: Hayward 26115vsp....pump suggestions
    Apr 2017
    Nyc
    25
    Was going to use the variable speed pump because i was thinking about an inexpensive solar panel on my garage roof..approximately 10ft but my pool builder doesnt think it will heat up pool enough but it was only .85 Hp..definitely not enough so here it is...pool is 15x24 oval aquasport 52inch...any suggestions..self priming pump but any suggestions..models..thanks in advance
    mas985's Avatar
    Pleasanton, CA
    11,988
    Re: Hayward 26115vsp....pump suggestions
    I am a little confused by your question. Are you saying your pump is not large enough? Have you tried it. I ran my solar on a two story house with 1/2 HP pump. What is the make model of the pump? Is it the Hayward 26115 or is that one you want? Also what is the size of your panels?
    Mark
    Apr 2017
    Nyc
    25
    Sorry if confusing..just wondering what kind of pump is suggested for my setup..gonna do saltwater Hayward and probably skip solar..so pump suggestions based on my pool size..thanks
    mas985's Avatar
    Pleasanton, CA
    11,988
    What kind of pump do you have now? Nearly any pump will work with that setup except maybe an Intex pump with solar. Without solar, any pump.
    Mark
    Apr 2017
    Nyc
    25
    New build need a pump suggestion
    mas985's Avatar
    Pleasanton, CA
    11,988
    Ok, if you like the 26115, that is a very good pump. Or a simple two speed like the Dynamo 1 HP. Just depends on your budget and what you are looking for. As I said before, any pump will do.
    Mark
    Apr 2017
    Nyc
    25
    The 26115 is less than 1 HP...need a 1 1/2 HP...thanks
    mas985's Avatar
    Pleasanton, CA
    11,988
    Why do you think you need a 1 1/2 HP?
    I currently run my 20k pool on a 1/2 HP pump using low speed most of the time.
    Mark
    Apr 2017
    Nyc
    25
    Pool builder said 1 1/2 hp...i previously had 15 ft round and used a 1hp..so thinking 1 1/2 hp is good for the size
    mas985's Avatar
    Pleasanton, CA
    11,988
    I don't think you need that large a pump. Plus using HP to size a pump can lead you astray. The Hayward vs is actually much larger than many 1.5 HP ag pumps.
    Mark
    Apr 2017
    Nyc
    25
    Ok..thinking about the Hayward sp2610x15 (pool builder suggested) or sp3010x15az...don't know what difference is though besides price..thanks for all your help
