Results 1 to 12 of 12
Thread: Air in line!
    Dec 2010
    El Dorado Hills, CA
    104
    Air in line!
    I've be trying to figure out where I'm getting air into my line. I ended up sticking a drain king into the inlet of the pump and saw a tiny drip at the first glued junction (in picture it's where the gray pipe hits the black). It's slow and while it's a pain to see air coming out of my pool bottom returns, hasn't really caused an issue.
    My question is can I simply apply caulking to the joint to stop the leak or do I need to replace the pipe? I hope it's not the pipe given the location.
    Thanks - Ed
    Mar 2013
    CT
    363
    Re: Air in line!
    I used this stuff last year around some of my PVC joints. I used the clear spray. It stopped the air bubbles that were in my filter basket.
    Flex Seal | The Easy Way to Coat, Seal, and Stop Leaks Fast!
    16 x 32 In-Ground vinyl, 21,000 Gallons, Hayward Cartridge Filter, Hayward Tiger Shark robotic cleaner, Taylor K-2006 Test Kit
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: Air in line!
    Is that on the suction side or return? If it is the suction side you can put little pvc glue where it is leaking with a syringe and the suction will pull it into the hole. Use the blue glue, it cures in the presence of water. Don't use too much, you can do it again if needed.
    Dec 2010
    El Dorado Hills, CA
    104
    Re: Air in line!
    Thanks. It's the suction side. I put a small bead of clear silicon caulking and will try tomorrow. If it doesn't work, I'll try the blue glue!
    Dec 2010
    El Dorado Hills, CA
    104
    Re: Air in line!
    The caulking fixed it. No more bubbles!! Now to my next problem... I think my spa has a leak.
    Dec 2010
    El Dorado Hills, CA
    104
    Re: Air in line!
    Well that was a short lived fix. I have air in the returns.
    Here's what's interesting. If I turn the valve to choose only one skimmer it's clear. If I choose the other skimmer it's clear. I didn't have time to let it run more than 15min per side but as soon as I turned it to both skimmers on I had air. Seems like that tells me the underground pipes are likely ok.
    Could this mean the valve I'm turning is somehow the problem? How can I check the hand valve?
    It could also mean the caulking fix didn't fix anything but I'm not sure how that explains what appears to be that I only get air if both returns are open.
    Ed
    Jun 2016
    Walhalla, SC
    275
    Re: Air in line!
    So you have a 3-way diverter valve before pump? What kind? They sometimes have O rings that are replaceable (Replacing the Jandy Valve O-rings; Pool Pump Not Priming Part 8 - YouTube)
    20x40 28kgal in-ground vinyl built 2011, liner replaced 2017
    Pentair Tagelus TA60D sand filter, Pentair SuperFlow 1HP pump, Intellichlor IC40 SWG, Dolphin Active 30i
    City water, TF-100 test kit + speedstir.
    Recommended Levels | Chlorine/CYA Chart | SLAM
    Dec 2010
    El Dorado Hills, CA
    104
    Re: Air in line!
    I have a three way jandy right before the pump that seperates the pool from the spa. On the pool side of that valve I have another jandy (manual) that seperates the two skimmer inputs. The one I believe is giving me trouble is the on that seperates the skinners. Of course the tucked it right up against the electric panel to the point that I can't pull it apart... I'd have to cut it out.
    I'm thinking because I need to ultimately fix my caulk leak just pulling it all apart and replacing it. I'm going to play a little more to try and isolate the issue.
    Stay tuned and THANKS!!!
    Ed
    Dec 2010
    El Dorado Hills, CA
    104
    Re: Air in line!
    Just looked at the video. I think I'll have enough room to remove the handle and pull the cover. I don't think I can get the diverter out. So as long as I can seperate the cap from the diverter and get to the O-rings it may work.
    I'll give it a shot on Friday.
    Ed
    Jun 2016
    Walhalla, SC
    275
    Re: Air in line!
    Yep, hopefully it's just the o ring and not a bad valve altogether. Plumbing in tight spaces is something I'm willing to just pay someone for...
    Dec 2010
    El Dorado Hills, CA
    104
    Re: Air in line!
    Quote Originally Posted by drharris View Post
    I hear you! I may take the route!
    Dec 2010
    El Dorado Hills, CA
    104
    Re: Air in line!
    Well I still have air in the line so it looks like my caulking job didn't work. Looks like I need to replace the pipe from the three way valve to the filter.
    Looking closely at the current pipe I can't figure out the best way to do this. Does the pipe going into the threeway screw out? It looks like it might. If so, looks like I'd need to screw both ends in then glue the centers together. Does that seem right? I guess I could call the pool guy.
    Ed
