Results 1 to 11 of 11
Thread: Water crystal clear, but vision blurry when swimming
    Jan 2017
    Alamo, CA
    25
    Hi,
    Our pool water is finally looking great and testing right. Had salt installed. Dumped in a ton of calcium. Took a lot of work, and thought we were finally ready. Perfectly clear when looking at it from the decking. But when you're in the water, your vision is blurry. It's hard to see the contours of your hand that is right in front of your face. Any thoughts on why? Is it the salt?
    FC: 4
    ph: 7.5
    TA: 60
    CH: 375
    CYA: 80
    Salt: 3200
    Temp: 85
    25k IG PebbleTec pool, waterfall, Pentair Intelliflo, 1.5 HP Pentair Pinnacle, Aqualink RS6 (All Button), Solar Heat, Solar Panels, Hayward Aqua Rite
    Mar 2016
    Easley, SC
    407
    Re: Water crystal clear, but vision blurry when swimming
    I do not have salt but had the same issue last year. Never could get a clear answer on it.
    18x36 inground / 28k gal / Vinyl liner (replaced in 2018) / Hayward Pro Series sand filter / Hayward 1hp pool pump / Hayward 3/4hp booster pump / Stenner pump (85MHP17) w/55 gallon storage tank / Pentair heat pump HP1200 (To be installed) / TF100 Test kit
    domct203's Avatar
    Jun 2015
    CT
    3,898
    Are you saying that when you are under water with a mask on, things are blurry?
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Mar 2016
    Easley, SC
    407
    Mine is clear with a mask. Blurry without.
    Jan 2017
    Alamo, CA
    25
    No mask. Just open eyes. For example, as I swim underwater toward the wall, I cannot see the wall until I am right on it.
    domct203's Avatar
    Jun 2015
    CT
    3,898
    Things are blurry without the mask because the water re-focuses our vision. That is why we wear masks.
    Underwater vision - Wikipedia
    Dom - TFP Guide
    Mar 2016
    Easley, SC
    407
    I have never noticed it before. Only after I went liquid chlorine. Maybe the water was always cloudy so it wasn't as noticeable?
    domct203's Avatar
    Jun 2015
    CT
    3,898
    Quote Originally Posted by E795 View Post
    That is normal for any body of water, pool, lake, etc.
    Dom - TFP Guide
    bmoreswim's Avatar
    Jul 2012
    Central MD
    4,152
    I agree. Always blurry with no mask in clear water. Certainly so for me.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,302
    This has never been an issue for me. I don't wear my glasses when I'm swimming, so it has always been blurry.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,125
    Like the rest of us who don't have an extra lens over our eyes like fish have, you seem to be perfectly normal.
    Divin Dave,
