Thread: Hayward de3600 clamp assembly replacement
    May 2017
    Wading river New York
    1
    Hi all
    first time poster but longtime lurker
    im about to begin my last summer with my Hayward de3600 filter before replacing it. Unfortunately the brass sleeves and t-bolts are shot. Last time I had to replace a brass sleeve I had no problem but now with it being discontinued I'm having a little trouble.
    Ive managed to get 2 new brass sleeve nuts but I'm stuck on the t-bolts.
    I found only one on Amazon but with really low ratings. I also found a pentair clamp assembly kit on ebay and I've used pentair grids before but I'm not sure if this one would work on my Hayward.
    does anyone know of either another site where I can get replacement t-bolts and/or if this pentair clamp will work.
    Regards
    krista
    ckk81's Avatar
    Jan 2015
    Kalamazoo MI
    235
    Re: Hayward de3600 clamp assembly replacement
    Quote Originally Posted by Atsirk View Post
    Hi all
    Regards
    krista
    As long as those t-bolts fit I don't see why they wouldn't work. Have you asked Inyopools.com?
    30K? gal (20x40, 3ft shallow to 8-9ft hopper), Vinyl IG, single speed 1HP pump, Hayward Micro Clear DE-3600 filter, Hayward Aqua Rite SWG T15 Cell, Rheem/Raypack M206A heater
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,296
    You might be able to make your own using all-thread and a barrel nut, if you can find the right thread diameter.
    Barrel nut:
