Thread: Kreepy Krauly or motor problem
    May 2017
    Johannesburg
    6
    HI there
    We bought a house few years back that had an empty fiberglass swimming pool, 2 years ago we decided to fix it, by replacing the fiber all went well for a year.
    when winter started we decided to not clean the pool, (bad idea i know), just before summer started i decided to get the pool ready. and noticed that the Kreepy works for about 5 minutes than stops. i plug out the hose and everything seems to be fine,
    what Ive done.
    Checked each hose for leakage/air seeping thru nothing.
    Checked the suction of each hose by putting my hand in front.
    When i put my hand by the front of the Kreepy the suction is gone.
    im out of ideas, dont want to buy a new vacuum only to experience the same problem
    Re: Kreepy Krauly or motor problem
    How many pounds of pressure in your filter?
    Could be lack of flow, or you could have a worn diaphragm, or you could be sucking up large debris that blocks the cleaner.
    UD
    20K Gallon Gunnite pool/900 Gallon in ground Spa/2HP WhisperflowSpa
    Pentair Master temp 400/Hayward Sand WZeobrite/Jandy RS-8 Aqualink/Jandy 2HP Epump
    12 - 4x10 Panels/Zodiac G3-T5 / BBB
    May 2017
    Johannesburg
    6
    thannks, where do i check the flow?
    Its been sucking up large amounts of leaves, any other way to remove them?
    There is a supplied meter with it that will give you an indication of flow.
    Your filter should have a pressure gauge, as pressure builds flow is reduced.
    Id net up large clumps of debris before I let the cleaner loose on the pool.
    UD
    Sfpat's Avatar
    Jul 2016
    tulsa
    113
    You are better off using another method to remove large amounts of leaves as the KK works best in a relatively clean pool with no large debris. I have a lot of trees in my yard and have to deal with leaves. I usually scoop most of the leaves with a leave rake, then vacuum the rest. Once the leaves are gone, I then put the KK in. The KK needs a consistent suction and leaves in the KK suction, hose, skimmer basket, pump basket, etc will kill the suction quickly.
    40 year old pool, 35k gal w/spa, gunite replastered July 2016, Hayward Sand filter, Hayward 1.5 hp single speed pump, TF-100, Kreepy Krauly suction side cleaner Dolphin M400
    May 2017
    Johannesburg
    6
    i havent seen any gauges will have a look and try taking a pic of the set up, i think maybe its old
    Quote Originally Posted by Sfpat View Post
    Trees suck, i will try this and post an update hopefully this is the solution to my problem
