Thread: Gunnite pool plumbing repairs needed
    May 2017
    Upstate NY
    7
    Hello TFP members,
    I have an older gunnite pool that's in need of minimally return line help, and possibly skimmer line as well.
    Is it better to attempt to repair the lines or replace?
    If replacing flexible or rigid?
    How deep for new lines?
    Use existing return holes or create new?
    Any referrals to upstate ny pros welcomed!
    15k gunnite pregnant kidney
    Jun 2016
    Southern California 562
    96
    Re: Gunnite pool plumbing repairs needed
    Quote Originally Posted by SwimmingMurphy View Post
    Hello TFP members,
    I did my own skimmer replacement, probably spent $250 total. However gotta have a power hammer to break away the concrete around the old skimmer, some hydraulic cement, epoxy and you're good to go, takes a few days without help or any experience.
    I redid all my plumbing also, I was going to rent a coring press to drill bigger returns, but just worked the old returns with the power hammer and made them about 2 inch big, inserted 1.5 lines and packed hydraulic cement into the hole on both the inside of the pool wall and outside the pool wall.
    May 2017
    Upstate NY
    7
    Seems to be controversial about flex vs rigid pvc. Most guys in warmer climates seem to like the rigid and cooler climates like what I fall under seem to prefer flex.
    Is there anyone that has a solid reason for one over the other?
    Jun 2016
    96
    I used rigid, I read that flex is prone to getting attacked by termites..
