Results 1 to 8 of 8
Thread: Still no hardness?
    Nov 2015
    VT
    87
    Still no hardness?
    I just refilled my tub. Soft water.
    My Taylor kit test says the sample should turn red if calcium is present. It didn't so I added 10 oz. calcium chloride and ran jets.
    Tested again and still no red. Added 10 oz. more and ran jets. Still no red. Tried my HTH test kit thinking maybe Taylor test was off. Still no red.
    What gives? Could my (old) calcium chloride (Balance Pak 300) have "gone bad"?
    Now I'm nervous that I've over-hardened my water and will need to start all over.
    Hot Springs Sovereign (1999?)
    30,956
    Re: Still no hardness?
    What does PoolMath calculator tell you?
    Jan 2012
    'burbs of Augusta, Georgia
    8,587
    I doubt your calcium went bad. Your test *maybe* ? How old are your reagents?
    Maddie
    Skippy's Pool Cooler --> Skippy's New Fountain Our Build --> Our Pool Solved Our Sloping Yard
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    It's not the reagent getting bad. Double check the dose and your test procedure.
    Essential Links:
    Nov 2015
    VT
    87
    Taylor kit and HTH kit both @ 2 yrs. old.
    Pool Calc said I needed @ 11 oz. of calcium chloride or 20 oz. of of calcium chloride dihydrate.
    Not sure which I have so I started with 10 oz. and got no red. Added 10 oz. more and still no red.
    350 gal. tub.
    30,956
    Well, your dosage is good so I think your reagents are faulty. 2 years old is probably too long to be reliable.
    Take a Giant step into pool management and get the TF-100 of Taylor K-2006C
    Nov 2015
    VT
    87
    Take a Giant step into pool management and get the TF-100...
    I'm using the TF-100 kit. Twice.
    Then I tried my HTH kit.
    Neither indicate any hardness.
    TheBraLady's Avatar
    Jun 2015
    Concord, NC
    178
    You might need to reorder the reagents. Do your other tests seem to be accurate?
    Pool Completed 8/2015 18'x36' Gemini shape 3.5' - 8', 19,200 gal IG vinyl, Hayward Max-Flo 1.5 HP 2-speed pump, Hayward Pro Series 300-lb sand filter, Hayward AquaPlus SWG, NO Autofill, Dolphin M400 robot, Taylor 2005 test kit, 434 gal Bullfrog A7L spa
