Results 1 to 9 of 9
Thread: Attached SPA impact on Pool Chemistry
    Esloser's Avatar
    Jun 2016
    Millville, NJ
    507
    Just curious... how does an attached SPA impact the rest of the pool's chemistry. I have a 6 jet attached spa that overflows into the pool when not in SPA Mode. I'm wondering how it impacts the pool chemistry - PH, FC, etc. with the water getting heated to 94-100 degrees and blowing air through it.
    Eric
    36,000 Gallon Inground (IG) Gunite Pool with Spa and 12" tanning ledge | White Plaster | Cartridge Filter | Hayward Single Speed Pump (x2) | 400k BTU Hayward Heater | Hayward ProLogic Automation | Taylor K2006 Test Kit | In-pool Cleaner | August / September 2016 Build Date | Build Thread
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,312
    Re: Attached SPA impact on Pool Chemistry
    The aeration drives pH up. Otherwise, there's no real difference between one giant pool and a pool with a spillover spa of the same gallonage.
    foobert's Avatar
    Jul 2013
    Bay Area, CA
    143
    Aeration will tend to raise you PH.
    Temperature has a minor effect on CSI values (you can see change in the Pool Math). Othewise, it's not much different than having well used and splashed in pool.
    ~john
    24.5K G, pebble, SuperFlo VS 1.5, 48sq DE filter, Hayward H250FDN, Autopilot RC-52, Poolvergnuegen & 3 daily swimmers in season.
    Esloser's Avatar
    Jun 2016
    Millville, NJ
    507
    I guess that helps explain why I go through so much Muriatic Acid - usually 2-3 gallons per week. It's also a new pool, so I have that working against me too. What about FC? Does warmer water use FC faster than the cooler water of the pool?
    Richard320's Avatar
    Jan 2010
    20,312
    Quote Originally Posted by Esloser View Post
    I couldn't say for sure. I only run the heater when I'm using the spa, and then I only heat the spa. A spa-load of water at 100 is only going to raise the rest of the pool 1 or 2 degrees. Not enough change to make a noticeable change in FC, I doubt.
    When I use the spa, I start my drawing the water down a few inches, so that when we get in, it doesn't overflow. Why heat it just to push it out? Then I set it to spa only and fire up the heat. There's less water to heat since it's already been lowered. Heats faster. I also don't like the blower and I restricted the air intake to the venturis. Why heat water and then blow cold air in it to cool it off? When we're done, I kill the heater and switch the valves and let it fill and spill out.
    Esloser's Avatar
    Jun 2016
    Millville, NJ
    507
    Do you draw from the pool at all when using the Spa? I was thinking of cracking open the pool suction line to pool a little bit of pool water into the spa to trickle it over the spillway. That way, if someone gets out, the spa will slowly return to the right water level. I haven't tested my theory yet.
    Richard320's Avatar
    Jan 2010
    20,312
    There's only the two of us that use the spa, so an inch or so is no big deal. When I have the heat on in the spa, I only want to heat the water in the spa and no other. Drawing from a cooler pool will just chill the spa.
    Jun 2016
    Berryville VA
    4
    I too have attached spa. Last time we used spa legs itched. Here are my numbers.
    Unheated FC 5 PH 7.4 TA 90
    Heated to 99 FC 5 PH 8.0 TA 90
    How low can I keep the PH in my pool so the heated spa PH is not so high?
    20k gallon IG pool & spa, pebble, Aquapure PLC1400 SWG
    Jandy DE filter mod # DEV60, Raypak 399k BTU heater
    Jandy pumps, 2.0 hp for pool, 1.5 hp for spa
    Polaris cleaner, 2' sheer descent
    Richard320's Avatar
    Jan 2010
    20,312
    Quote Originally Posted by windyknollsva View Post
    It's not the heat. Heating the water should lower pH PH levels
    The spa is probably churning with bubbles and aeration drives the pH up. When I attacked my high pH with acid & aeration, I let the spa run full bore and drove the whole pool's pH up from 7.2 to 7.6 in about 4 hours. You might find that lowering the TA in the whole system will slow the pH rise in the spa. I don't care much for all the froth and I don't see any point in heating the water only to cool with cold air, so I don' run the blower and covered the venturi intake so I just get hot water.
