Thread: New to TFP
    May 2017
    Jonesboro, AR
    33
    New to TFP
    We have had a FG pool for several years and have trouble keeping chemicals balanced. Thought we would try this method this year. Hope it works. I am trying to learn as much as I can.
    IG, 24,000 gallons, Fiberglass, Triton II TR 60 sand filter, Taylor TF 100 test kit
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: New to TFP
    Welcome to TFP!
    It has worked great for my pool for many years now! Start with a little reading here, ABCs of Pool Water Chemistry And here, Pool School - Getting Started
    Donldson's Avatar
    NW Ohio
    3,219
    Re: New to TFP
    Welcome to TFP!
    Biggest "don't make my mistakes" advice I can give you is get yourself a proper test kit right away. I don't admit it often but I tried TFP with a 6-way Taylor kit and it went far better than before but I still had problems. I haven't had a single problem since getting the TF-100 because I can see the problems coming before the water even starts to lose its shimmer. It is an investment and trying to do TFP with test strips will end up costing more than getting the right kit right away.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath
    May 2017
    Baldwin NY
    3
    Re: New to TFP
    Welcome, I am new to. In fact I just registered. I will be making a post soon.
