Results 1 to 10 of 10
Thread: So Long Old Ultra Frame, Hello New One....
    May 2013
    Janesville WI
    74
    Well our old Ultra Frame lasted 4 seasons and it's got to go. Legs were rusted by the plastic pads and the liner was not to be repaired anymore. I think we got our money out of it Just went and picked up the new "style/color Ultra Frame. (2) intake ports will be nice and I actually like the new color better. Also it seemed like the upright connectors ("T") connectors are a little more aesthetically pleasing. Just waiting for the weather to cooperate and new one will be assembled. Just FYI I used a SWG for all the years and no rust from that....rusty legs were from nasty winter weather here in WI and a small leak we couldn't find...lol.
    Intex 18x48/2650 Sand/56601E SWG
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,296
    Re: So Long Old Ultra Frame, Hello New One....
    Don't toss out the old uprights and T connectors. Somebody will need them. List 'em on eBay or just be patient. Someone here will be lamenting the difficulty in locating one soon enough.
    Same situation here. Got 4 seasons out of the old one. Some rust around some of the feet. Just put up the new model this weekend. Like the new T connectors. Although I will say getting the last pole together was fairly difficult. On the previous model, you could slide the connector in past the clip to get the extra space you needed to connect. Can't do that with this model.
    I cut out the 2 outlets and hard plumbed the pool and added a side skimmer and anti-fatigue mats under the pool. (They made all the difference in the world) No wrinkles at all. Will make the pool bug's job of cleaning the bottom much easier. Nice spongy feel when you're in the pool. I also like the new color and having bright blue squares again.20170507_173937.jpg
    Jun 2014
    Fountain Hills, AZ
    34
    Curious..what are anti-fatigue mats?
    Intex AG 22' x 52" Ultra frame, Intex 2650 pump, sand filter and SWG
    Hayward in-wall skimmer, Wanda the Whale, center fountain, Intex magnetic light
    Richard320's Avatar
    Jan 2010
    20,296
    Quote Originally Posted by grannydi View Post
    Closed-cell sponge rubber. Sorta like wrestling mats from school days. Search results for: 'antifatigue'
    Jun 2014
    Fountain Hills, AZ
    34
    Interesting. These are used in place of foam sheets under the liner?
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    2,192
    There are quite a few people that use the mats in place of sand or ridgid foam boards under an above ground liner.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    Yeah, I purchased them from harbor freight for $7.00 per pkg. Ironically, it took 18 pkgs to do the job for an 18" pool. They interlock together, but I still used gorilla tape to hold the seem just in case. It really takes care of a lot of bottom of pool issues. I had sand, tarp and gorilla pad under the last one, and still developed crevices/depressions/wrinkles where dirt would collect and make it difficult for the pool bug to clean. Perfectly smooth now. Really nice to walk on, also.
    I left the sand/tarp gorilla pad in place due to it being nicely compacted and flat from the previous pool. I bought 2 12"x 8' trex boards and planed them down to 1/2" and cut them into 6" pieces and just laid them on my existing concrete blocks to make up the difference the 1/2" pad made.
    May 2017
    Fresno, CA
    37
    How much was your deck and what size?
    Exactly what iam looking to do.
    I believe it's 14' wide x 12' deep. Can't remember the exact price. A couple hundred in materials. I built it myself.
