Thread: Algae Growth On Grout Below Water Line
    waldrondigital's Avatar
    Jun 2014
    Simi Valley, CA
    4
    Our Breeze SWG cell wasn't producing chlorine at an acceptable level, so I replaced it which solved the issue. FC was almost non-existent for a brief time, but is around 4 now.
    I'm having issues with minor bright green algae growth below the water line on the grout. I've brushed it off twice, but it comes back after a few weeks in certain low light spots. It's not pervasive.
    What are thoughts on using this method to kill it?: How To Clean Algae From Swimming Pool Tile Grout - INYOPools.com
    Any other suggestions? I saw about spraying bleach, but it seems that that is geared to algae ABOVE the water line, and obviously I can't spray underwater. Although I suppose I could let the water level fall so I could get to the affected areas with a sprayer.
    It's growing in the shaded area of this picture:
    Thanks TFP!
    In-ground plaster 17k gallon pool & spa with flag stone decking, Jandy DEL60 Filter, Pentair Intellifo Pump, Jandy RS6 Controller, Jandy LX400N-L Heater, Zodiac MX-6 Robot, SGS Breeze SWG.
    Jan 2012
    'burbs of Augusta, Georgia
    8,550
    Re: Algae Growth On Grout Below Water Line
    What are your test results?
    Maddie
    Skippy's Pool Cooler --> Skippy's New Fountain Our Build --> Our Pool Solved Our Sloping Yard
    30,941
    Lowering the water is the best cure.
    More chlorine is the preventative
