I identified my skimmer as an Admiral S20 Skimmer. I was thrown off initially by the replacement Weir not fitting properly. After placing my camera through the skimmer I see that the installer forced the skimmer into place and the side walls are slightly inward bowed...this was my issue.
But I digress
I see from Pentair exploded view that my skimmer has or had an "Equalizer" or "Float Valve"
I have a side suction port on my pool that is connected to a Kreepy Krauler.
The 2 things I read that the "Equalizer" valve does is:
1. Protect pump from clogged skimmer or low water
2. Pull water from the main drain
Am I right thinking that this is already done through my side suction cleaner?
But I digress
