Thread: Salt Cell issues
    Mar 2016
    Ponce de Leon, Fl
    6
    Salt Cell issues
    I have an intellichlor salt cell. All last summer I dealt with it not producing any or enough chlorine. So I used mostly liquid chlorine all last summer. This season we have acid washed it, although no scale was visible on the blades and it did not bubble up. I was told a few weeks ago at the pool store that I had high levels of phosphates in the water and this would cause the chlorine to be used up as fast as it could be produced. Should I proceed with a phosphate treatment? The SWG system itself does not show any error messages and does not have any scale, so I don't know if it has simply gone bad and time to replace. It is probably 4 to 5 years old.
    Bridget Alford
    28K gal, IG plaster
    sand, Intellichlor SWG
    Filled with well water
    Jan 2017
    Monterrey, NL, Mexico
    492
    Re: Salt Cell issues
    Hello and welcome:
    Can you please post test result of you water? Also what test do you use?
    This way we can help you better!
    Felipe
    7,500 gal Rectangular, Easytouch 8, Air+water temp sensors, Screenlogic2, IC40, intellibright5g color12v, Intelli pH, SD 70 filter w/Zeolit, Magicstream Laminars, waterfall. Raised Monolithic concrete lined with glass beads.
    In Sunny Monterrey,Mx!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    It is best not to acid clean swg cells if there is no scale present, it will shorten the life of the cell. Which intellichlor do you have? The most common reason people think their swg is not producing enough chlorine is because there is a low level algae bloom growing in the pool using up all the chlorine.
    Post some test results and perform an Overnight Chlorine Loss Test to see if there is something growing in the pool. How does the water look?
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,323
    Bridget,
    I too would like to know the size of your SWCG. I would also like to know what output percentage you normal run, and for how many hours a day.
