Thread: Liner Lock
    Apr 2012
    South Dakota
    87
    Liner Lock
    I opened my pool cover and the corners of the pool have the liner lock popped out. Usually in the spring it is popped out a little and I just go around and push it back in but a few of the corners really popped out about 2-3 feet worth. Is there a non-permanent adhesive I can use to get the liner lock band the stay or should I just replace it. The liner is older than 5 years and it is still in place despite the liner lock band popping in some spots.
    Thank you
    18600 Gallon In Ground
    Vinyl liner
    Aqua Genie Skimmer/Return
    Purex Triton Challenger wet end with Emerson 2EZ Speed Two-Speed with Timer Motor 3/4HP #EB2980T
    Sta-Rite 145361 Cristal-Flo II High-Rate Sand Filter 22Inch
    Taylor K-2006
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    33,917
    Re: Liner Lock
    Pop-icicle sticks! You can tuck some of these behind the linerlock and it will stay in. You can also use pennies but if you have kids those might not last LOL
    Kim
    Apr 2012
    South Dakota
    87
    Re: Liner Lock
    Good idea. Thank you.
    Vinyl liner
    Taylor K-2006
