Thread: Pipe rebuild underwater
    May 2017
    Safety Harbor FL
    3
    I'm going to be rebuilding my suction-side manifold, and have FOUR pipes that are about 8 inches under the pool water level. #1 skimmer, #2 vacuum robot, #3 main drain, #4 spa drain. I expect I could temporarily use pool side plugs for #1 and #2, but is there a way to block the drains? Otherwise I would have to use a wet PVC glue, and cut, deburr, bevel, clean and glue while the water is running out. That's possible, but messy. (I could lower the pool by 10 inches also ...)
    Thanks for suggestions!
    Tampa FL area, 10,600 gallon in-ground, with "spa", built c. 1994.
    Thimble's Avatar
    Apr 2013
    Wichita, KS
    93
    Re: Pipe rebuild underwater
    That's what I would do. An "extended backwash and rinse" .
    15x30 IGP; 20,000 gallons; plaster
    Hayward SP2607X10 Pump; Purex Triton Tagelus Sand Filter
    Hayward Goldline T-Cell 15 SWG; Aquarite G1 Control
    Southwest Spas 400 gallon hot tub w/ozone
    TF 100 with speed stir
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,297
    WTG,
    Your only real option is to drop the level of your pool water below the level of any repairs...
    It will be much less work, and a more reliable repair than trying to do it under water.
