Thread: Adding Muriatic Acid Question
    Apr 2017
    Lawrenceville, GA
    23
    I'm testing with a Taylor K2006. After today's pH test I landed at roughly 7.9. It took roughly 2 drops of reagent to get the pool back to the range I'd like. I'm curious about how to read this chart, though:
    I feel like these amounts are for the pre-diluted compound of muriatic acid and water, but I just want to be sure. Are the amounts listed in the table the total amount of muriatic acid I should dilute, or is that the total amount I should add of the pre-diluted solution?
    For example, let's say I have a 5,000 gallon pool and it took 2 drops of reagent to get back into ideal range-- do I need to dilute 9.16 FL oz of muriatic acid? Or do I need to create a diluted mixture of muriatic acid with water and then add 9.16 FL oz of that compound into my pool?
    This forum has helped me get up to speed quicker than I hadever imagined as a new pool owner. Thanks as always for any guidance you all can provide.
    8,300 gal, IG fiberglass, sand filter, Taylor Technologies 2006, AutoPilot Nanodigital SWG
    DeanP66's Avatar
    Mar 2014
    San Jose, CA
    703
    Re: Adding Muriatic Acid Question
    That should just be for straight acid out of the bottle. It says 20 baume/ 31.45% HCI, which is full strength muriatic acid. So, for 5000 gallons, just measure 9 to 10 ounces of acid in a measuring cup and pour it in front of a return that is running.
    Pool size: 20,000 Gallon Plaster Pool, Pump: Hayward Tristar VS SP3202VSP, Filter: Pentair Clean and Clear Plus 320
    Polaris 280 Pressure side cleaner, Solar cover, Pentair Amerilite LED pool light, Taylor K-2006C test kit
    Apr 2017
    sacramento CA
    147
    Yes, but make sure that's the % of acid you are using. if you have 14.5% MA, like I do, you will need to add more than what it says.
    Apr 2017
    Lawrenceville, GA
    23
    Quote Originally Posted by DeanP66 View Post
    Good call, thanks for pointing out the table title lol. I saw a lot of people mentioning diluting MA and I think that threw me off. Thanks for the assist, much appreciated!
