Thread: Question on Pool LED light replacement
    May 2016
    Arlington, TX
    225
    I really had put little thought into a replacement light because the first guy I spoke to mentioned having to pull the line all the way from the power source but now I realize that may not be the case. My light works fine but I am kind of interested in the possibility of an LED light. Can't you just replace the light like a normal light in a socket? Understanding there are sealing issues.
    Apr 2016
    Orlando FL
    48
    Re: Question on Pool LED light replacement
    There are some "replacement" bulbs that are LED, and some color-changing LED replacement bulbs. You need to buy the replacement bulb to fit your specific light model (have the correct base type, etc.).
    Take a look at this site http://www.inyopools.com/ProductList...=category-page
    20K gal In-ground pool w/spa; IntelliControl, IntelliChlor, IntelliPH (Acid-Injector), SAM/SAL lights, Pentair FNS60Plus filter, two 1.0 HP WhiperFlow pumps, Jandy/Compool auto-valves, RayPak Heatpump, Jandy Gas heater
