Thread: Adding a vacuum port-Intex 24x52 Metal Frame ool
    May 2017
    Kilgore/Tx
    1
    I am looking into cutting a new port for vacuuming our 24 x 52 Intex Metal Frame Pool. What supplies are needed to cut the hole and Install port? Where can I purchase items?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Re: Adding a vacuum port-Intex 24x52 Metal Frame ool
    Welcome to TFP Wanda!
    Someone who's done this ought t be along before too much longer. Best of luck, and enjoy your summer.
    Essential Links:
    domct203's Avatar
    Jun 2015
    CT
    3,913
    I used a standard Hayward wall fitting, and put it right in the original hole in the liner. I'm not sure of the exact model number, but this should be it:
    http://www.inyopools.com/Products/07501352030405.htm
    The newer pools will require you to cut out the original opening.
    They also make vacuum port adapters with spring loaded covers that screw into the Hayward fitting.
    http://www.inyopools.com/Products/07501352028003.htm
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    chayne's Avatar
    May 2016
    Somewhere Around The Red River, Texas
    419
    i ordered mine off of amazon: https://www.amazon.com/Hayward-SP102...nut+and+Gasket
    i actually ordered another one tonight so i could add another outlet so i can hook up my intex auto pool cleaner. that way i dont have to keep taking my return jet off.
    Charles
    Coleman 16'x48"
    Intex 16" pump & Sand filter, Intex Robot Vacuum
    Hayward Wide Mouth Skimmer
    TF-100 Test Kit Magnetic Speed Stirer
