Thread: Drained pool, help ID these stains on surface
    Apr 2014
    Central Tx
    62
    I've been dealing with a staining issue the past couple years that I haven't been able to remedy so I decided to drain this year to see if I can get a better look at the stains and to see if I can tackle the issue. I'm dealing with two separate stains here. The entire gunite surface is covered in what looks like a green stain which is shown in the pics. I also have a lot of brown staining at various parts of the surface which is shown as well. Last year I tried a no-drain acid wash which did pretty much nothing. I also tried the vitamin C and chlorine tablets on the stains last year to no avail. Any help?
    BTW, all these pics are taken after I pressure washed the entire surface.
    23,000 gal, in-ground, plaster with 24" sand filter, 1.5" piping.
    Re: Drained pool, help ID these stains on surface
    Looks like multiple issues including copper, iron, scale, etching and it even looks like the pool was painted at one point.
    I would suspect that the chemistry has been all over the place.
    Support the site
    Apr 2014
    Central Tx
    62
    Quote Originally Posted by JamesW View Post
    Anything I can do right now while the pool is empty to make the surface look better?
    Would an acid wash help or possibly hurt considering the condition of the surface?
    The surface is in rough shape. An acid wash might clean it up some but will make it very rough.
    Not a lot of good options.
    Support the site
    DeanP66's Avatar
    Mar 2014
    San Jose, CA
    703
    My pool had similar stains to those(probaby worse) about 2 months ago and I decided to drain and do an acid wash. It was pretty easy once I got the water drained and although my plaster has seen better days, it cleaned up nicely after the acid wash. I just used a watering can with about 8 gallons of Muriatic acid (full strengh) and diluted it in the watering can with water to about 2 to 1 acid to water ratio. I poured about a 7 to 10 foot section at a time and scrubbed it with a brush as well and hosed it off toward the deep end where my utility pump would pump it out of the pool. When I finished the entire pool I did a little touch up in spots that I wasn't quite pleased with and when finished, I refilled the pool. Came out really nice.
    Pool size: 20,000 Gallon Plaster Pool, Pump: Hayward Tristar VS SP3202VSP, Filter: Pentair Clean and Clear Plus 320
    Polaris 280 Pressure side cleaner, Solar cover, Pentair Amerilite LED pool light, Taylor K-2006C test kit
    Apr 2014
    Central Tx
    62
    Thanks for the replies.
