Thread: Travertine Deck and Coping
    Hey_Zeus's Avatar
    Mar 2017
    Orlando
    48
    We just passed Under ground electric and pumbing, so we can move onto grading, and decking!
    We picked a Tumbled Travertine coping and deck, it looks awesome in the crates! I have a few questions I hope ya'll can help out with.
    We are going to be installing about 120 Linear Ft of Leonardio Bullnose Coping and about a 1100 sq ft deck Ivory Travertine.
    I saw on another post about using a sealer on the bond beam of the concrete. I haven't come across that anywhere in looking into how to install Travertine coping. Anyone have experience with a travertine coping installation?
    Also, I have read a lot about using Flexbong mortar at 1inch thick. Sound about right?
    What is the spacing between coping pieces? 1/4 or 1/5 inch?
    What is the overhang you have? We were thinking 1 - 1.5 inches....?
    Travertine Mart: How to install travertine patio pavers
    Here is what the coping looks like with a piece of the deck next to it. Base rocks and sand going in this week, coping done by the weekend.
    Jun 2016
    East Central MS
    117
    Re: Travertine Deck and Coping
    Really nice looking stone and tile.
    My coping is Indiana limestone drawn on CAD software and spec'd by an architectural stone company that does this often and they suggested a damp course under the stone (which we did not do) and 1-7/8" overhang (which we did do). This makes our overhang nearly two inches but it looks fantastic. With that in mind, I'd suggest at least 1.5" overhang.
    I'd consider sealing the travertine as well.
    Natural Stone Treatment WB Plus
    34K gal, 20'x40' IGP (backfilled and reinforced concrete block walls with concrete floor built mid-1970's; renovated 2017), PebbleSheen Arctic White plaster finish, Lotus Prisma Marine 1x2 glass waterline tiles, Indiana limestone coping, 1.5hp Hayward pump, Pentair Triton II TR100 sand filter, Pentair Intellibrite 5g color LED 120v Pool Light, Dolphin Supreme M400 robot, Stenner 45M1 pump, Pentair 320 chlorinator (to raise CYA only)
    Hey_Zeus's Avatar
    Mar 2017
    Orlando
    48
    Quote Originally Posted by pushin glass View Post
    We will definitely seal the stone, that's a no brainer.
    What do yo mean by "damp course under the stone" and why did you elect to not do it?
    Jun 2016
    East Central MS
    117
    A damp course is an impermeable barrier underneath masonry that prevents water from passing through the masonry from beneath via capillary action (so-called rising damp). It is typically placed at the bottom courses of masonry in a house to prevent water from rising up and causing mold and mildew problems in the house. We elected not to do it because we thought it would be too hard to prevent water from entering the stone from beneath from pool splash, et cetera, and since our pool water would have a pH closer to the stone and have appropriate bicarbonate and calcium levels, we would just be paying the mason more money for little if any gain. The main damage to the stone will be from above (acidic rainwater and salt attack). They spec the damp course primarily for liability purposes.
    Check out the second picture to see a damp course installed: Damp Proof Course Twin Pack
    Does the quarry provide any installation specs? Our architectural stone firm recommended normal type N white mortar with a setting bed of 1"-1.5". When the stone is placed on top it typically compresses the mortar to somewhere between 0.5"-1". White mortar was recommended as it has no added coloration which can stain the stone. Also, our mortar joints were spec'd to 3/8" which our mason followed. This was important because ours were cut precisely to fit.
    As a bit of history, when structures were purely masonry and not stick frame with masonry veneer, rising damp was a common issue and used to stain the plaster inside the building near the floors. This is why wainscoting was created. They would panel the lower portion of the wall with a rot-resistant wood to prevent the damage and unsightly discoloration from the rising damp.
    Jun 2016
    East Central MS
    117
    Another architectural stone company's spec sheet. They call for 1-1/8" overhang and no damp course.
    https://www.google.com/url?sa=t&rct=...DGb368BLYzXwcg
