Results 1 to 13 of 13
Thread: Ok testing done finally
    Noobpool's Avatar
    Apr 2017
    Cullman , Al
    64
    I have been slamming for a few days now and I finally think I am getting close. Woke up today and it was the first time I had a residual FC (2). Added more calcium hypo to bring back to proper levels and my cc was 1ppm. Once I get that to Below .5ppm how often does everyone test to maintain proper levels? My cya was 60. Water hardness was low (70)which is why I am using Cal hypo
    I understand that I still need to do the overnight FC test to make sure that I am maintaining FC levels and such. I am going to aim towards 8ppm as maintenance levels.
    20x40 40k vinyl pool, hayward pro series S220t sand filter with vacuum pump and pentair model 320 in line feeder. No clue as to what type of skimmers I have. Just got my k-2006 test kit.
    Noobpool's Avatar
    Apr 2017
    Cullman , Al
    64
    Re: Ok testing done finally
    Good deal? I am not sure if it goes bad. Thoughts?
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    10,155
    Residual FC of 2? During a SLAM? What is your current CYA? Heck-post a full set of test results!
    Noobpool's Avatar
    Apr 2017
    Cullman , Al
    64
    Calcium hardness is 70 cya of 60 I have slam level of fc to 28-30 and when I check every few hours it drops down to the teens and I readd chlorine to put it back between 28-30 range but overnight the first 2 nights I register 0 fc first test so today having 2fc was headed in the right direction. Cc was 5 when I first started and the water was black/green. I just retested now and fc was 19 so I am going to bump back to 28 and test again at dark
    Noobpool's Avatar
    Apr 2017
    Cullman , Al
    64
    Cc just hit .5ppm too
    Noobpool's Avatar
    Apr 2017
    Cullman , Al
    64
    Just retested
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,542
    First and foremost, WELCOME!!
    Your numbers really don't look that bad. How does the water look??
    Noobpool's Avatar
    Apr 2017
    Cullman , Al
    64
    Not sure why my CC numbers jump around though. Was low earlier and it jumped up again during the evening test
    Jan 2012
    'burbs of Augusta, Georgia
    8,571
    Vinyl pools don't need calcium. Too much calcium could also cause problems. Isn't bleach cheaper for the amount of FC you need for a SLAM?
    And yes, bleach weakens over time and with heat/sun exposure. Consider that before buying a big honkin' supply of it.
    Maddie
    Skippy's Pool Cooler --> Skippy's New Fountain Our Build --> Our Pool Solved Our Sloping Yard
    Noobpool's Avatar
    Apr 2017
    Cullman , Al
    64
    Pool is milky opaque when I was brushing the sides and bottom getting a lot of green afterwards from the bloom I had. Today brushing did not alter it from chalky white or so
    Noobpool's Avatar
    Apr 2017
    Cullman , Al
    64
    I just bought 10 gallons of 10% for $45 from walmart. Through doheny I got 24 lbs of Cal hypo for $60ish
    Jan 2012
    8,571
    Pool can be milky both from the calcium as well as dead algae. Hard to know which but the solution is filtering.
    Keep up the SLAM!
    Maddie
    Noobpool's Avatar
    Apr 2017
    Cullman , Al
    64
    Yeah I plan to hopefully get pool right and maybe next weekend clean my sand filter, top off the sand leveo if it is low (bought this house and pool last September so just getting my feet wet with maintenance) the previous owners said they just never turned the filter off the pressure guage on the filter is currently inoperable but I have a replacement. That should allow me to have a consistent baseline for back washing. I am also thinking really hard about a poolskim since it appears to be extremely effective
