Page 1 of 2 12 LastLast
Results 1 to 20 of 26
Thread: 1 week down on new plaster pool, will be swg in 3 weeks, questions
    Aug 2016
    Baltimore Md
    56
    Thanks for all the help so far this site is awesome!
    45k gallon diamondbrite , I'm battling high Alk with muratic acid and I have been adding bleach(not same time) , can't get the alk down and can't get the fac up, should I be adding anything else? Will be turning swg on in about 2 weeks. Is the fac getting burned up due to no stabilizer? The stabilizer says for chlorine pools only which mine is but only for 2 more week?
    Apr 2017
    sacramento CA
    147
    Re: 1 week down on new plaster pool, will be swg in 3 weeks, questions
    Yes if you have 0 cya the FC gets used quickly. I'd add some liquid stabilizer and get the cya up to at least 50. You are going to need it anyway when you do turn on the swg.
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,298
    M,
    Actually, SWCG pools use much more CYA than non-SWCG pool. Our recommendations are for a CYA of 70 to 80 with a Saltwater pool.
    With zero CYA your FC will quickly get used up. For now you need to have a CYA of 30 and when you go saltwater bring it up to 70 or 80.
    See this.. https://www.troublefreepool.com/cont...mmended-levels
    There is no way to tell what to recommend on the TA, as you did not tell us what it is .
    Unless your TA is off the charts, for now I would worry much more about my pH which you also did not mention.
    Please post a full set of test data...
    FC
    CC
    pH
    TA
    CH
    CYA
    Aug 2016
    Baltimore Md
    56
    I will do test kit in the Am and post results in this thread, thanks.
    Aug 2016
    Baltimore Md
    56
    Today's test is as follows
    CH 0
    ph 7
    alk 120 ��Getting better
    ch 450
    cya 0
    i have not added anything for cya yet should I do that today? I have 4 gallons of instant conditioner liquid stabilizer and no reading of ch yet even after putting 6 gallons of bleach in pool throughout 3 days.
    also I have waterfall running to raise Ph.
    thanks
    Also I have a question the CH numbers I'm giving you is from the k-1000 kit is that Fca or ch?
    and how do I get the other number?
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,091
    Yes, aim for 30 on CYA if you have 0. When your SWG is installed, bump it up to 70.
    Do you have a TF-100 or a Taylor 2006? That is how we get precise chlorine numbers. We don't worry too much about total chlorine, just FC and CC.
    Also, to avoid confusion, can you post results (going forward ) in the format Jim posted above? You have CH twice, which most people will assume is Calcium Hardness. So
    FC
    CC
    Thanks!
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Aug 2016
    Baltimore Md
    56
    Tf-100 and sorry for confusion, I'll add bleach and stabilizer today and post back later
    thanks
    Aug 2016
    Baltimore Md
    56
    Ph 7.2 Alk 120
    Ph is on low accept range and alk is on high accept range
    should i I add more muratic acid or run waterfall all day then add?
    thanks
    Jul 2014
    Bedford, TX
    9,298
    M,
    Leave your pH and TA alone. pH will go up on its own.. and at this point I would not worry about the TA..
    triptyx's Avatar
    Apr 2016
    1,476
    Quote Originally Posted by Mr Bruce View Post
    FC
    CC
    Thanks!
    Before adding a bunch of stabilizer, let's make sure he doesn't need to SLAM.
    OP - can you please add enough stabilizer to get to 30ppm, and once there, use bleach to get to FC 6 around sundown, wait half an hour with the pump running, then perform the OCLT (instructions: Pool School - Perform the Overnight FC Loss Test (OCLT) )
    8,500gal plaster in-ground with attached spa, two floor drains, one skimmer. Chlorine, City Water.
    Pentair WhisperFlo 1hp Pump, MagnaTek Midcentury EPlus motor, Pentair CleanNClear 200SF Cartridge filter, Purex Triton MiniMax 250 Gas Heater, Pentair SunLite, AutoFill.
    Kreepy Krauly Cruiser, TF-100 with SpeedStir. :D
    Aug 2016
    Baltimore Md
    56
    I did bring stabilizer up to 30ppm yesterday and added bleach my level was around 3 this morning should I still slam?
    keep in mind new plaster thanks a bunch!!
    triptyx's Avatar
    Apr 2016
    1,476
    An OCLT will tell us if you need to SLAM or not. What was your FC level after adding bleach yesterday?
    Aug 2016
    Baltimore Md
    56
    Wat is a OLCT?
    thanks
    May 2016
    West Bloomfield, MI
    757
    12,000 gal Diamond Brite indoor​ pool. Pentair Triton TR-60 Sand Filter +added DE, Lochinvar Energyrite ERN-200 gas heater, Pentair Multi-valve, Pentair SuperFlo VS pump, TF-100 kit, Pool Math App - iOS
    Aug 2016
    Baltimore Md
    56
    Ok one question is the daily blue kit that comes with tf-100 test ph and FC? If so here are my tests today, definitely lost chlorine today this am it was at 3(going by blue kit in tf-100)
    FC 0
    CC
    PH 7.2
    TA 120
    CH 475
    CYA 35
    triptyx's Avatar
    Apr 2016
    1,476
    The FC test in the little blue kit (it's called an OTO test) is extremely unreliable, however, it is good for determining if there is some chlorine in the water.
    If it is saying there is none, I suspect you may be on the edge of having an algae problem. You'll want to use bleach to dose the pool immediately to reach FC7 using PoolMath. Then follow the OCLT steps we've posted above. Report the results here please.
    Aug 2016
    Baltimore Md
    56
    I just added the bleach to get the FC to 7, am I checking this with the blue daily kit tonight?
    Aug 2016
    Baltimore Md
    56
    Ok now we're cooking I understand hot to do the FC and CC test my evening results are
    FC 11
    CC .5
    report back in the am
    triptyx's Avatar
    Apr 2016
    1,476
    Awesome, please use the FAS/DPD test for chlorine (looks like you got that already). We'll look forward to seeing the results in the morning. Please remember to get results before the sun rises and hits the pool (I know, getting up that early is terrible!)
  20. Back To Top    #20
    Aug 2016
    Baltimore Md
    56
    Morning test results
    FC 10.5
    CC .5
    i should not on both tests when I add the solution to get the water red again after the FC test , the water was pink or barley red .
    somwhat do these numbers mean am I good? And what do I do next?
