Thread: Sand Filter Size
    Mar 2017
    Crestview Fl
    3
    Sand Filter Size
    I got a great deal (free) on a slightly used pentair variable speed pump (1.5). I am looking at buying a sand filter and I want to buy the right size. Pool size is 24 round x 52 above ground. Been reading on here a lot and it seems that bigger is better, and I want to get it right the first time. Any suggestions would be appreciated. And on a happy note, we have finally started on the ground work for the pool, hope to get it out of the garage soon. Thanks in advance and I hope that everyone is having a wonderful day!
    In progress pool build to be partially inground
    Round 24 foot Lomart above ground pool presently located in the garage
    No pump or filter purchased yet
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    2,192
    Re: Sand Filter Size
    19" or larger for the sand filter. Kinda wished I had pushed for a 20" or 22" filter when I put my pool in but I didn't know enough to push for it.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    Mar 2017
    Crestview Fl
    3
    Thanks for the answer, been thinking about getting a 24".
    Jun 2016
    boiling springs, SC
    99
    i would say 24 or 26 now with it being VS pump your good with a 22 or so but at full speed u will need a 26+ too strong for the smaller ones.
    23,000 in-ground salt water pool with liner, 1.5 HP 2 speed Pentair pump, Hayword C4025 cartridge filter, Jandy SWG.
