Thread: Dolphin DX6 Issue
    Louisiana
    127
    Dolphin DX6 Issue
    Went to use my Dolphin DX6 for the first time this season and it will not power up. The power supply turned on for about 2 seconds then went off and will not power on at all. is there something i can fix myself and check for or does it look like the power supply is no good? Is it worth fixing or just get another one? i have had it for about 4 years now. Thanks
    27' Radiant Metric, 17,100 gallons
    Pentair Dynamo 1.5hp 220v
    Circupool RJ45, Sand Filter, Borates
    Dolphin DX6 Robotic cleaner
    TF 100 Kit
    Killer95Stang's Avatar
    Sunny SoCal
    698
    Re: Dolphin DX6 Issue
    Sounds like a power supply issue to me. If you pull it apart and nothing is obviously wrong inside that can be easily fixed, then you are stuck getting a replacement. New they are $200, so you have to weigh that against buying a new robot.
    Pool done!! (backyard = work in progress) 32' x 19' inground freeform with 7' spa, baja step w/ (2) bubblers, stonescapes mini pebble finish, rock waterfall feature, 12" raised bond beam, Intelliflo VS, Whisperflo feature pump, (3) 5G Color LED's, FNS + DE 60, 400K Master Temp, Easytouch 8 w/ remote, Intellichlor IC40, Vision Classic Ceramic Kamado smoker, Margaritaville DM1000!!! Party Coming Soon!!
    TF-100 Test Kit w/ Speedstir
    Louisiana
    127
    Quote Originally Posted by Killer95Stang View Post
    Thanks for the reply and i figured it would probably be that. And yes the question now is buy a power supply or something else.
    TF 100 Kit
