Thread: CH is a little high. How should I lower?
    Jan 2015
    Tuttle/Oklahoma
    147
    Here are my current readings.
    FC: 5.5
    PH: 7.5
    TA: 120
    CH: 450
    Salt: 3400
    Should I do some water replacement or is it close enough that with summer and the weekly evaporation/top off regiment, will it work itself out?
    My Pool Build Thread: 21 x 40 Freeform Gunite Pool, 12" Tanning Ledge, 3.5 shallow graduating to 4.5, 8.5 deep end, 4' Waterfall which doubles as a diving ledge with 6' x 4' Grotto underneath, 670 sq. ft., 106 Linear ft., Rock Salted Concrete Deck, Pentair 520 Filter, Intelli flow 3 HP VS pump, (4) Color LED lights, Intelli-Chlor SWG, Hot Springs Vanguard Hot Tub with ACE and BT Sound System, ODK, TF100
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,312
    Re: CH is a little high. How should I lower?
    Evaporation and topoff won't lower CH, it will raise it.
    450 CH is out of the ideal range, but it's not all that difficult to keep it maintained. Above 800 CH. my experience has been that it starts getting difficult to keep CSI in range, but you're a long way from that.
    If you do decide to drain and refill to lower CH, remember that you'll be lowering salt and CYA by the same amount.
    Jan 2015
    Tuttle/Oklahoma
    147
    So there really is no "good" way to lower CH other than a partial drain and refill? If the evap/refill just raises it, I am guessing that a partial drain and refill is in order every 2-3 years or so.
    Richard320's Avatar
    Jan 2010
    20,312
    Quote Originally Posted by SoonerWing View Post
    Maybe. Depends on rain and snow. They have no CH. If you drain off half the water to winterize and open top a full pool, your CH will be half what it was in the Fall.
