Results 1 to 10 of 10
Thread: CLOUDY Water
    1ginger1's Avatar
    Jul 2015
    willows, ca
    9
    CLOUDY Water
    Not sure if I am in the right place to post. I couldn't find the Topic List? What is my problem?
    I want to discuss my cloudy pool.
    40,000 gal. In ground plaster pool, 20'x40'x 10' deep, resurfaced 2013, nonSWG, DE filter
    Jun 2014
    17,333
    Re: Cloudy Pool
    Hello! A cloudy pool is usually an indication of algae trying to bloom. Do you have a TF-100 or Taylor K-2006 test kit to post test results? That's what we really need to see first.
    FC
    CC
    CYA
    PH
    TA
    CH
    Don't worry about forum placement of your thread. We'll move it if we need to.
    1ginger1's Avatar
    Jul 2015
    willows, ca
    9
    CLOUDY Water
    Was not able to take care of pool during winter so it was very green and full of leaves and gunk. I have gotten rid of the algae. It is now 2 months into working on it and I can not get a clear pool.
    We are using the TFP 100 kit. Before I tell you todays test---We had a very low PH and test said to put in 46 lbs. of Soda Ash. We put in 24 and then the PH went up so high that the test then said to put in 3 gal. of Acid. So we started out with 1 gal. Now PH is fine BUT:
    Chlorine: 3.6
    PH: 7.2
    CYA: 55
    FC: 7
    CC: 0
    CH: 250
    TA: 280
    CSI: 0.16
    It doesn't tell us to put anything in. We have vacuumed for 3 days, cleaned out the filter basket many times, back washed 5 times and two days ago cleaned out the DE filters, washed thoroughly and replaced new DE. oh yes, forgot to say that we have used 6 bags of SHOCK during all this.
    We need to put this house up for sale and can't until this pool is clear. HELP HELP HELP
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,303
    Re: CLOUDY Water
    Cloudy after green means you stopped maintaining shock level too soon. Check out the SLAM article. With 55 CYA you need to get FC up to 22 and keep it up there. That'll finish off any lingering algae trying to regroup and counterattack.
    1ginger1's Avatar
    Jul 2015
    willows, ca
    9
    CLEAR -- Not Swimable
    At the last post the water was milky and it was suggested I needed to get the FC up to 22. I got it to 26 and then lowered it. Have used mostly bleach rather than shock.
    Now the pool is essentially clear, just a little hazy, not sparkly. Have cleaned the DE filter twice and vacuumed twice.
    Test this AM:
    Chlorine 6-7
    PH 7.5
    FC 10
    CC 0
    CYA 60
    CH 375
    TA 290
    I just vacuumed and back washed twice. Water was low so am bringing it up. Our water is high Alkaline so should raise the PH.
    Will wash DE Filter again tonight and then run all night and test in AM
    QUESTION: Once the water is clearer but the FC is high and the Chlorine is high how do I get it swimmable?
    40,877
    Re: CLOUDY Water
    I merged your threads. Please keep related questions together. Thanks, jblizzle
    It does not sound like you are following the SLAM process. You should be maintaining the high FC level until you pass the 3 criteria to stop.
    FYI, the pool is safe to swim up to shock FC level for your CYA. Right now you are WAY below that, so assuming you can see the bottom, the pool is "safe" to swim in.
    Sep 2016
    Escondido/CA
    641
    Re: CLOUDY Water
    Are you adding DE back in once you backwash?
    Backwashing can often not remove all the DE, so how much are you adding back in? If you are adding in the full amount, you may have added too much DE.
    Are you cleaning when the pressure increases by 25%
    It *seems* like a lot of cleaning for a DE. Is it undersized for your pool?
    Could the milky stuff be DE?
    Maybe do a full open it up and clean it?
    Jon -- 28kgal, IG, AquaBright, Attached Spa, ~1990, Quad DE 80, Easytouch8, IntelliFloVS-3050, Intellichlor60, IntelliPh, Dolphin DX6, City Water, K-2006/TF-100, SpeedStir, SampleSizer, San Diego, CA
    1ginger1's Avatar
    Jul 2015
    willows, ca
    9
    Re: CLOUDY Water
    OK, we are now beautifully CLEAR. What a job and pain AND expense. Thanks for all your suggestions. Now will keep it beautiful. I hope NOT to talk to you for a long while. Have a great swimming summer!!
    Apr 2017
    Alexandria, LA
    25
    Re: CLOUDY Water
    Quote Originally Posted by 1ginger1 View Post
    How did you get a resolution? Did you just keep the shock levels until it went clear?
    ~11,500 gallon in-ground 27 x 13 ft
    3 ft in shallow, 5.5 ft in deep
    Plaster bottom/fiberglass sides(?)
    1ginger1's Avatar
    Jul 2015
    willows, ca
    9
    Re: CLOUDY Water
    The two biggest things I did was keep adding bleach until the FC was over 22, actually went up to 26. Then vacuumed a lot and backwashed a lot. Now the FC is 14 and I am keeping it there for awhile. The Pool Math now says that I need to add or delete nothing. That is great. For this large pool and the cloudiness in it we had added 46lb. of baking soda before I found how to start slamming. As it says above, I had stopped slamming too soon. They were right. I am 80 and I am exhausted!! Now that the pool is clean we are now selling, I can't take this any more. smile
