Results 1 to 10 of 10
Thread: Any recommendations on cleaning out this surface drain?
    CajunGuy's Avatar
    Apr 2016
    Louisiana
    303
    We are adding a few additions to our pool slab (please disregard the mess and tree stump lol) and was wondering what you guys thought would be the best way to clean out this surface drain? If I had to guess, it's about 20ft across and about 1.5" wide and 3-4" in depth. The drain holes are too small to really get a hose or pressure washer to be useful. There was a lot of landscaping before (previous homeowners were not so bright) that caused a lot of dirt to get inside and weeds tend to grow often in it now. What would be the easiest way to clean it out?
    15k Gallon In Ground Saltwater Gunite Pool and Spa w/ Overflow
    Dolphin S200 Pool Cleaner
    Main Filter Pump - 1.5HP Pentair Whisperflo connected to Triton II Sand Filter
    Spa Pump - 2HP Pentair Whisperflo w/ 2HP Polaris Spa Air Blower
    Resilience PSC3 SWCG
    samwestx's Avatar
    May 2016
    Weslaco, Texas (DEEP SOUTH TEXAS)
    102
    Re: Any recommendations on cleaning out this surface drain?
    Soak the drain up with hose water for a bit and pull......or ROUND UP
    15000 gallon pool (15x30 + 7x7 sitting area), IG-Blue Pebble, Sand Filter-Hayward Pro Series, Pump-Hayward Tristar VS pump, Water Test Kit-TF 100, NEW POOL-COMPLETED ON 5/7/16, City Water w/no restriction, Dolphin M400
    CajunGuy's Avatar
    Apr 2016
    Louisiana
    303
    Quote Originally Posted by samwestx View Post
    Sent from my SAMSUNG-SM-G900A using Tapatalk
    The drain is cemented in place. I've been using weed juller, but would like to clean out the dirt.
    samwestx's Avatar
    May 2016
    102
    Sorry, misunderstood your post.....does your drain have a removable top? Some do......mine had to be cut out and replaced by the builder when they had installed the wrong color.......
    samwestx's Avatar
    May 2016
    102
    Just the top was replaced.....snaps in
    CajunGuy's Avatar
    Apr 2016
    Louisiana
    303
    Hmmm...I'll have to look at it more closely, but it looks like the entire drain was just mortared in place.
    JoyfulNoise's Avatar
    May 2015
    14,093
    Not many options without cutting out some section of channel drain to get a hose into it or removing the entire length of channel drain and re-doing it. Weed killer's like Round-Up are post-emergent killers, they need to be absorbed by the leaves to be effective (root absorption is minimal due to soil fixation of the glyphosate). If you spray a pre-emergent weed killer in there, it will kill all of the sprouting seeds before they every get out of the soil.
    Matt
    CajunGuy's Avatar
    Apr 2016
    Louisiana
    303
    Both sides are open though, so I was thinking maybe a long piece of rebar.
    samwestx's Avatar
    May 2016
    102
    That'll soften it up.....then stick a hose gun in there kinda like trenching under a concrete section to fish electricity to the other side
    Jul 2015
    Tempe, AZ
    194
    For a few bucks at Home Depot you could rig up some fittings to your hose that would let you jam a long length of 3/8" poly tubing thru the drain and blast out the debris.
    John - 16,000 gallon | in ground | pebble | Triton II sand filter | TF100 | speedstir | Hayward Phoenix 2x
