Results 1 to 8 of 8
Thread: New to the forum and new to pool ownership
    Apr 2017
    Buffalo/new york
    4
    Hello everyone, I'm having problems with my pool. First of all, I'm new to all of this. Last year I moved into my house and struggled all season to maintain my pool. Spent a lot of money at The pool store and It got worse. I couldn't maintain my free chlorine. This year I'm having the same problem but I stumbled upon your website. I just bought a k-2006 test kit. My numbers were
    FC .2
    CC .2
    Ph 7.4
    TA 90
    CH 140
    CYA 100
    temperature 54
    25k gal, vinyl IG, 3/4 hp Hayward max flo, sand Hayward pro series, Polaris 9550 robot
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    10,158
    Re: New to the forum and new to pool ownership
    Welcome to the forum. That CYa needs to be about 40----------replace water, partial drains and fills. FC gotta come up to match that.Pool School - Chlorine / CYA Chart
    Jun 2014
    17,340
    Welcome to TFP!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,311
    Welcome!
    I predict great success with your pool this year. You've been reading, you filled out your signature, you bought a test kit, and you posted results! The one thing you omitted: How does the water look?
    For sure the CYA is too high and you'll be happier in the long run if you replace some water now. Beyond that, it sorta depends on how the water looks and what test results you have after refilling and mixing.
    Oct 2015
    San Diego, Ca.
    805
    As mentioned your CYA seems high but it could really be much higher, effecting the FC target. There is a test where you double the water and keep the same quantity of R-0013. Next, double the results you get. You my be surprised how high that CYA really is. Give it a try and post it. (.2 FC is way too low under most conditions)
    P.S.
    Lesson #1- Listen to these guys NOT the pool store sales people....Always
    35,000 Gal. - 40x20x8 - Plaster - SWG Pentair IC 60 - Barracuda G3 Vacuum - Hayward c1750 Cartridge Filter - Blue Torrent VS 1.5hp pump - Pool is 45 years old.
    "I'd build a deck over my pool if I didn't have a SWG"
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,297
    Collin,
    Welcome to TFP... A Great resource for all pool owners who can't get their chlorine up...
    I assume that you have been chlorinating your pool using 3" chlorinated pucks.. Pucks work great at first, but as they release chlorine into your pool, they also release CYA. The chlorine gets used up, but the CYA continues to build up.
    Once the CYA gets high enough, you almost can't put enough chlorine in your pool to make it work.
    You say you have a CYA of 100, but that is as high as the test can go, so you may have a much higher CYA level.
    As woody says, your only option at this point is to drain your pool.
    Now is the time to think about how you plan to chlorinate your pool going forward..
    Thanks for posting,
    Apr 2017
    Buffalo/new york
    4
    The water looks pretty clear. I'm gonna drain some of the water and fill it back up. Any suggestions on how much to drain
    Yep 3" pucks. I'm done using those and now gonna try the BBB
    30,954
    With a CYA of 100, I would drain 50% of your pool water so your CYA will be at a manageable 50 ppm.
