Results 1 to 8 of 8
Thread: Intex pool cleaner hookup question
    chayne's Avatar
    May 2016
    Somewhere Around The Red River, Texas
    419
    i broke down and bought an intex pool cleaner. i took it out of the box, and then i realized i do not have the right parts to hook it up. i have the hayward return eye. can anyone help me in getting this thing hooked up? i cannot think of anyway to get this thing going.
    Charles
    Coleman 16'x48"
    Intex 16" pump & Sand filter, Intex Robot Vacuum
    Hayward Wide Mouth Skimmer
    TF-100 Test Kit Magnetic Speed Stirer
    PoolMumsy's Avatar
    Apr 2017
    Ft Worth, TX
    36
    Re: Intex pool cleaner hookup question
    Good news!! If you're talking about this one or one like it, it hooks up to your inlet/return valve and functions with a vacuum created by water pressure not pump suctions. Easy button...yay!!
    Hope that helps.
    Blessings from Texas
    P.S. The "leaks" at the hose section joints are intentional in the design, apparently.
    https://www.amazon.com/Intex-28001E-...+pool+cleaners
    Intex Ultra Frame 18' x 52" pool, Intex Krystal Clear 15k SWG, Intex 2500GPH pump , Intex Auto Pool Cleaner
    Previously owned an in-ground gunite pool /hot-tube with a Nascent Oxygen Generation purification system. Frankly, it was the bomb, but grateful for Intex.
    chayne's Avatar
    May 2016
    419
    yes that is the one i am talking about. my problem is i cannot hook it up to the return jet without making mods to the return jet. i am going to home depot to find a way to get it going.
    Charles
    Coleman 16'x48"
    PoolMumsy's Avatar
    Apr 2017
    Ft Worth, TX
    36
    Oops, my mistake. I misread.
    Good luck!!
    chayne's Avatar
    May 2016
    419
    well i think i got it beat. i got a 1 1/2" screw in connector then i went to a 1 1/2" to 2" adapter then to a 2" screw on fitting. looks like it will work. i will see in about 2 hours when solar cover comes off the pool for the day so we can swim.
    Charles
    Coleman 16'x48"
    chayne's Avatar
    May 2016
    419
    she is cooking along the bottom of my pool now.
    Charles
    Coleman 16'x48"
    PoolMumsy's Avatar
    Apr 2017
    Ft Worth, TX
    36
    Woot!!
    Apr 2017
    Cabot, AR
    3
    Chayne, do you have pictures of how you did that? I have the same setup (hayward skimmer & auto intex vacuum) and cannot for the life of me figure out how to get this thing to work. The hayward skimmer came with a vacuum attachment but I don't think that works with this intex auto vacuum because it uses the return valve. But like you, I have the hayward eyeball return and it does not hook up.
    18' x 48" Summer Waves AGP, Hayward skimmer, 2500 intex sand filter
